tbi timing problem
Old Jun 24, 2008 | 12:28 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
tbi timing problem
okay i can set the timing w/o the est wire hooked up,and it runs great! burns tires really well. but as soon as i hook up that wire forget it it wants to fall on its face ,and if i turn anything on (heater ,wipers ) it dies. but if i leave it unhooked everything works and motor doesn't die. can i run it w/o hooking that wire up, or will it mess something up?
Old Jun 24, 2008 | 03:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tbi timing problem
What does the timing do once the EST BYPASS connector is re-connected? Check it with the light.
RBob.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
