rpms at idle? search diff. answers
Old Jun 27, 2008 | 12:59 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
what should my car be idling ,cold start, then warm up. i searched and got alot of different answers. right now it idles at 1000, then only kicks down to 800! still sounds too high.
Old Jun 27, 2008 | 03:33 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: rpms at idle? search diff. answers
My cars pretty much totally stock right now and I only idle at maybe 500rpm. So yeh that does sound a little high.
Old Jun 28, 2008 | 01:44 AM
Ruiner's Avatar
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
upon cold start, the rpms on mine are 1200-1500, and slowly drop over about a minute to around 1000. Once I put it in gear, it drops to 800
Once the engine warms up, idle in gear is right at 500, 800 in park/neutral
Old Jul 1, 2008 | 03:34 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Doesent sound horrible. If it really bother you, you can get the EBL flash computer [dynamicefi.com] because I know it has a different warm up routine for the computer [soon as you start it it doesent rev up too 1000, it just gets to its normal warmed up rpm] if you want to be cheap, you could try seafoam.
Old Jul 2, 2008 | 10:24 AM
Ronny's Avatar
I would pull the IAC and do a cleaning of it along with IAC passage in TB.
Old Jul 2, 2008 | 11:35 AM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
I agree, my tbi motor is mostly stock and I'm running 1500-1800 on cold start up, and when the engine is fully warm it usually idles around 500-600 rpms
jklein337
Sep 19, 2018 06:23 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Bradsaundry
Aug 12, 2015 12:34 AM
