Fuel pump failure?
Old Jun 30, 2008 | 01:43 PM
Ronny's Avatar
Fuel pump failure?
Car ran fine this morn to office. This afternoon wont go over 50 mph and reads 16/1 on WB cruise at 45 mph. EBL shows a code for FP relay? I suspect that means "fuel pump failure" as the car does run OK up to 45 mph and relay just turns on pump right? TPI pump only about 5 years old. I will check FP gauge at TBI unit tonight revving engine in driveway and see if it maintains 19 lbs under light load. comments?
Old Jul 1, 2008 | 07:52 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Fuel pump failure?
Fuel pump relay failure indicates low/intermittent voltage at the pump or relay itself. Definately sounds like its causing a fuel delivery problem.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
