Loss of power during acceleration...
Old Jul 10, 2008 | 08:47 AM
musclecarfan87's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305ci TBI
Transmission: 700R4 Auto w/ OD
When I'm on the highway or interstate, and hit it to get up to 60, the car seems to shudder a little bit, like its lacking fuel or something .
Upon further inspection yesterday, I noticed a clip is broke on one of the harness connections going to the driver side injector. Could this be causing the harness to keep losing connection and therefore making me lose fuel? Can I replace just the connector, or do I have to replace the entire harness? Could this also be causing the vibrations at highway speeds? I didn't get a chance to look it up in the manual yet.
Thanks.
Old Jul 10, 2008 | 12:57 PM
Brian21's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0L TBI
Re: Loss of power during acceleration...
One of the injector clips is broken on mine too.. I don't have any problems with it, but it's always made me kind of nervous. I actually found just the injector connector with clip at napa. You just splice it into your harness to replace the old connector.
Old Jul 11, 2008 | 11:07 AM
Engine: 305ci TBI
I'll have to get me one then. What I really don't like is the fact that I had a clip break... Over my throttle body.... Which leads into my engine...
Maybe that's what that big hunk of debris was on my spark plug when I changed them......?
Old Jul 11, 2008 | 04:39 PM
DM91RS's Avatar
Car: 91 RS
Just don't let a bolt [even a small one] drop down there..........don't ask why....it sux
Old Jul 12, 2008 | 05:44 PM
Engine: 305ci TBI
That would suck....
Old Jul 12, 2008 | 06:03 PM
DM91RS's Avatar
Car: 91 RS
Yep....cracked a 3 month old L31 block......my luck sux
Old Jul 15, 2008 | 08:36 AM
Engine: 305ci TBI
ouch
Old Jul 20, 2008 | 07:53 AM
notguilty_25's Avatar
Car: 89 camaro
something else i would check to... i didnt see whether or not u run cats. if so and it turns out that the injector clip dont work. i would check the cats. my car wouldnt hardly get up to 85, i thought it was just a terd. and when u have it in neutral and mash on it, it takes about 7 second to hit 3500 then it would die down. so i went and bought plugs, wires, and a rotor. and while i was in town, i wanted to make it loud for my gf who was driving it to **** her off. so i bought a 12" glasspack to bring home and weld on. well when i pulled the pipe off the cat. OH CRAP! there was my problem. all clogged and broke up in the pipe. cleaned all that out and gutted the rest of the way. and now the car will do about 125 estimated for a completely bone stock 305. but if u dont have cats... sorry for rambling. have fun take care
Old Jul 21, 2008 | 01:43 PM
Engine: 305ci TBI
It might be an exhaust problem.... I know the kid put 3in pipes w/ some kind of muffler on there.... I don't recall there being cats on there..... I haven't messed w/ the car in almost a month now. It's sitting over at the garage at my parent's house w/ a cracked rim..... I'll check that and get back to ya. Good idea though.... I didn't even think about cats. Thanks!
Old Jul 26, 2008 | 11:38 PM
Engine: 305ci TBI
Update.... Got the car back on the road a few days ago.... She runs strong, just has a slight shudder every now and then, and doesn't have very good acceleration....
I had an issue with spark plug wires melting on factory exhaust manifolds when I first got the car.... Thought I had fixed it.... Apparently not..... I think that's my main problem.....
I bought the wires today..... Putting them on tomorrow.... Will update then...
Anyone have any problems with their spark plug wires melting on a completely stock engine? I posted in the General Engine and Tech forum too to try to get some answers....
Last edited by musclecarfan87; Jul 26, 2008 at 11:39 PM. Reason: Added last paragraph
Old Jul 27, 2008 | 01:31 AM
vjo90RS8's Avatar
Car: 2002 Z28
fuel pump? Before the fuel pump went out on my old 90 RS it started to shutter but only when I was on the throttle 50-100% or when I would try to accelerate from 60mph to XXmph on the freeway. Thought it was a spark plug or wire but turned out to be the pump.
Old Aug 7, 2008 | 08:36 AM
Engine: 305ci TBI
Hmmm..... I hope its not the fuel pump..... I need to change the filter. I have one, just haven't had time to do it, nor the place to. Mine shudders around 60-70 when I am keeping a steady speed, then stutters when I hit the gas.... I also have a broken injector clip, so it may be that as well.....
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
FreeSpirit
Aug 29, 2015 05:47 PM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
