How can you tell the difference in 305/350 injectors
Old Jul 25, 2008 | 04:23 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
I'm still trying to verify what was swapped and what wasn't when this 350 was put in my car by the previous owner. Can you tell which injectors you have by looking at them? I am guessing they are 305 injectors, since the computer wasn't swapped.
Old Jul 29, 2008 | 03:48 PM
matts383rs's Avatar
Car: 1992 camaro RS
Engine: 383
Re: How can you tell the difference in 305/350 injectors
by the nozzle of the injector there should be differnt colors painted on it. Im not sure what color means what but I think a 350 injector is brown and something. If you go to Turbocity.com and look up injectors there is a break down of what the colors mean and the size of the injetors. A 350 should be a 61 or 68 lbs injector i think?
Ronny's Avatar
GM has part # on top of inj. need to remove the top cap(2 screws) to see #. check them both to make certain are not mismatched.
Old Jul 30, 2008 | 08:12 PM
Engine: 350 TBI
My bad, when I opened the Tb and looked at the injectors I didn't realize that they were inside that pod. I will have to open it to take the injectors out and look. Are those gaskets easy to find?
Old Jul 30, 2008 | 10:00 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Napa sells a carb kit for the Throttle body. I just bought one yesterday.
bamaboy0323
Sep 3, 2015 06:07 AM
Justin92GTA
Aug 27, 2015 11:16 PM
Thornburg
Aug 27, 2015 08:33 PM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
