Car Going Dead! Please Help!
Old Aug 2, 2008 | 05:59 PM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
Since I bought my 92 firebird, It has had a problem. When It would get to about a quarter of a tank of gas and I'd hit the brakes, the engine would go dead. As long as I had gas in it, it was fine though. Today it went dead several times and had plenty of gas. It even tried going dead on the highway. I had to pump the gas pedal. My guess is that my fuel pump is messed up and I need another one. I could be very wrong though.. Please help!
Wes
Old Aug 2, 2008 | 07:25 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Car Going Dead! Please Help!
Fuel pump is in the tank the fuel filter is under the drivers side of the car. Replace the fuel filter first, its cheap and easy and may be the problem.
Old Aug 2, 2008 | 11:41 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
I replaced the fuel filter sometime last year. So I doubt it is the filter.. I guess I'll end up dropping the tank.. Let me know if it could be something else though.
Old Aug 3, 2008 | 12:39 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Sounds like a vacuum leak if your car dies or stalls when applying the brakes. With the engine running, spray some carb cleaner or wd-40 around engine, vacuum hose, and base of tbi. If your rpm changes then you definitely have a vacuum leak. Try it before dropping your fuel tank. May even want to put a bottle of heat in the gas tank incase water maybe present.
Old Aug 3, 2008 | 02:05 AM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
I agree with the vacuum leak. The power booster has a vacuum check valve. I've had one crack which can cause a massive vacuum leak. Can be as simple as the grommet it sits into also. I don't know why having more gas in the tank would help though.
Old Aug 3, 2008 | 10:59 AM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
i will look for vacuum leaks and see if I can find any. Thanks for your help. I will let you know how it goes.
Old Aug 3, 2008 | 11:25 AM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
no vacuum leaks. Next I will try some gas treatment to see if there is any water in my tank.
Old Aug 3, 2008 | 11:45 AM
dstss's Avatar
Engine: 5.0 TPI
Did you check for vacuum leaks with the brake pedal down?
Old Aug 3, 2008 | 09:51 PM
Brian21's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0L TBI
Have you checked your fuel pressure yet? That might give you a good idea of whether your fuel pump is on it's way out or not.
Old Aug 3, 2008 | 10:28 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
I checked for vacuum leaks with the brake on and off and did not find one.
My fuel pressure is fine until I get to a quarter of a tank and hit the brakes.. I can't figure it out. I filled up with gas and put a bottle of iso heat in the tank. I think it has water in it, or the in-tank pickup could be messed up. I won't know for a couple of days if I still have the problem or not.. hopefully not, but I am not usually that lucky lol. I'll post what it does when I get down to a quarter of a tank. If it could be anything else be sure to let me know.
Thanks again for all of your help
Old Aug 4, 2008 | 09:05 AM
kcb37's Avatar
Could be that the pick up is bent in the tank, and hitting the brakes makes the fuel slosh forward and not get picked up.
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
