poor performance
Old Aug 8, 2008 | 08:04 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
poor performance
i bought my car awhile back and ever since i did a tune up on it it has a high idle and is slow and after it runs for about 5 min i can shut tha car off and open the butterflys in the tbi and smoke comes out? oil pressure and everythings fine but my car is balless ever since i changed plugs air filter fuel filter pvc valve and thermostat anyone else have this problem
Old Aug 8, 2008 | 09:48 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: poor performance
Did part of your tune up include checking the timing?
Old Aug 9, 2008 | 06:54 AM
kcb37's Avatar
Is your check engine light on?
You may want to check your TPS, and your IAC.
Old Aug 9, 2008 | 01:39 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Did you change the plug wires as well? Another possibility is having one or two wires crossed unless you changed the plugs and wires one at a time.
Gene
Old Aug 9, 2008 | 06:00 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
my engine light isnt on and my plug wires arnt crossed my tps is fine. im not sure how to check the iac but i cant figure out why it idles so high. my vacuum lines are fine but if im doing 60 my car is at about 4000 rpm and it idles at 1500. before the tune up it idled around 800 and could cruise 60 at about 2000 but my timing shouldnt move after a tune up i didnt move the distributor but i changed that cap and wires would that mess with the timing?
Old Aug 9, 2008 | 10:12 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Yes, changing the cap and/or rotor requires at least checking the ignition timing. I check mine even if I only remove & reinstall the same cap.
Old Aug 25, 2008 | 01:29 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
thermostat installed right? not backwards ?
Does the car eat oil ?
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
