porting my swirl port heads...
Old Aug 21, 2008 | 08:26 AM
Jammin'Trey's Avatar
Hey guys, What machine work will I have to have done it I want to take out my heads and mill off those stupid swirls blocking my ports? Would I want to throw some new springs on there too? I am just curious. Otherwise I would buy a set of Double hump corvette heads for 300$ from my buddy. I think they would really free things up and would be much easier on me.
Either way will those corvette heads bolt right on?
Old Aug 21, 2008 | 10:11 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: porting my swirl port heads...
you can't port out the swirl ramp in your heads, from what I understand there is a water jacket in that general area. Just get a bowl blend, 3 angle VJ back cut valves and a full port on the exhaust side. should do you just nicely. Those double hump "vette" heads will make you lose a good deal of compression. 58cc vs.76cc. that will kill power in most cases.
Old Aug 21, 2008 | 10:47 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
'Trey - check casting number of those heads first. Most double hump or camel back heads had 64cc - for example 462 heads. If you are going to put them on you will loose compression - hence power. Also, many of them came with large intake valves 2.02 which may come close to cylinder bore of your 305. The other bad thing is that camel back heads lacked accessory holes (most of them, but not all). By the time you are done with machine work on those older castings you are much better off getting a modern after market heads that were designed for 305 from the beginning. It is a bit more money, but you have to figure a total cost of ownership. I would not use camel back on todays engines - they are not as good, unless you are doing 100 percent restoration job on a 'vete or period correct 1st gen.
//RF
Old Aug 21, 2008 | 12:13 PM
TheBadazz's Avatar
Car: Pontiac T/A
Axle/Gears: Borg Warner 9-Bolt w/ 2.77 gears.
Imo I wouldn't waste time on the stock heads or the humps. Just find you some vortecs ( from a local salvage yard) and get a good 3 angle valve job with good springs. Also have the machine shop set them up for your intake bolt holes. You'll have a good start if you want to upgrade the motor in the future.
Old Aug 21, 2008 | 03:00 PM
You really can't use your stock intake with vortecs. even if they are drilled for the factory intake the runners on the heads are to tall for the stock intake to handle. Meaning you'll either have one hell of an intake leak or worse, coolant leaking into the engine.
Old Aug 21, 2008 | 04:11 PM
TheBadazz's Avatar
Car: Pontiac T/A
Yeah your right with that. Well I've built some 305s, LG4s, TBIs and TPIs and what i did with my old LG4 was to port the stock (non swirl port) heads, 3 angle valve job, ss 1.94 1.50 valves and milled down a bit. That motor with a cam, intake, headers, exhaust and chip made enough power to beat TPI 350s and 305s that I came across. But I ended up building a 355 in the end. Wish I would have done that in the first place.
Old Aug 22, 2008 | 08:23 AM
Can I use my 305 TBI unit with a vortec intake off a 305 truck.. I am trying to find a u pull it with a truck that had tbi vortec I guess. I am looking for 275-300hp so am guessing a ringed 305 with heads cam and exhaust as well as intake will get better than 12mpg and make good HP, I really like having a 305, if you had a really powerful one it like an underdog. Throw a cam in it when I put the heads in and run it while I save upfor an EBL tuner....
Old Aug 22, 2008 | 03:34 PM
RFmaster's Avatar
Car: 75 Beast
Thats a good long term approach. Just couple of notes.
Stock truck vortec manifold is not your performance oriented piece - GM performance has one, but it is pricey (+$300). Alternatively you can get Performer Edlebrock Vortec with a TBI adapter plate. In both case check for hood clearance.
Stock Vortec heads will not handle over 0.480 lift - this will require a trip to a machine shop and new springs (you'll need them any way)
To be fully emissions compliant you'll have to plumb exhaust gases from exhaust manifold for EGR functionality - there are couple of writeup on this subject (google it).
With a full exhaust, better intake, minor port job and a cam should be able to hit 250+HP with that combo
To support higher power levels you may need to bump up fuel pressure from 13 PSI to about 20+ - this may require a new fuel pump
EBL is the way to go. Also consider WBO once you get your combo going.
Final word - plan, read, research before spending any money or turning wrenches.
//RF
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
