TBI IDLEING HEADACHE
Old Aug 22, 2008 | 09:25 AM
JAMES .D's Avatar
I HAVE A 1992 CAMERO RS IT HAD A 305 TBI, NOW IT HAS A 350 4 BOLT MAIN 60 OVER . STILL TBI IT IDLES WITH A LOUP LIKE IT HAS A CAM FROM HELL. ITS A STOCK CAM, REVS FINE I REBUILT THE TBI , PLAYED WITH THE TIMEING , BUT STILL THE CAR ROCKS AT IDLE, MABY SOMEONE HAS HAD THIS . ANY INFO WILL HELP, THANKS.
Old Aug 22, 2008 | 03:23 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: TBI IDLEING HEADACHE
Well if youre using the stock computer that could be an issue.
Old Aug 22, 2008 | 03:42 PM
Ronny's Avatar
Take a peak at my thread "pulsating idle". Much may apply to you.
Double check for vac leaks at TBI base.
++NOTE+++ not all TBI units use same gasket. some can leak air where the IAC unit resides. the one sent to me with a carb manifold adapter(Howell) would have made a serious leak.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Sep 4, 2015 07:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
