Open element Air Filter
Old Aug 21, 2008 | 11:31 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Hey ya'll, its common knowledge this is a good way to get more power out of a TBI setup, but what kind of effect has it had on everyone's fuel economy?
Old Aug 22, 2008 | 03:34 PM
pete92rs's Avatar
Re: Open element Air Filter
No negative affect on my fuel consumption, I have not however ever noticed an increase in MPG. The only mod that I have done that increases MPG was adding headers.
Old Aug 25, 2008 | 12:09 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
MPG did not change at all for me. All it did was make my car run smoother and slightly better throttle response, still not that great. More of a supporting mod I think. BUt like I said no MPG change for me...
91 305 5-speed
Old Aug 25, 2008 | 12:49 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
no change in mpg either here, but i notice that at night when its nice and chill out, feels a bit more powerful with the Open Air setup then the stocker.
Not to mention your car will breathe alot better, it can breathe 360 now instead of just 30degree chunk
Old Aug 25, 2008 | 10:54 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
An open element air cleaner simply eliminates the restriction created by the small single snorkel. Then, the next most restrictive component quickly comes into play. In no particular order - throttle body, intake, valves & heads, cam, exhaust manifolds, catalytic converter, exhaust pipes, and muffler.
If I recall, I got a little better throttle response. But, no significant increase in power or gas mileage. I hear a dual snorkel w/ ducting to pull in cooler air from outside the engine bay is actually a better configuration.
Although, open elements look good in my opinion ...
Old Aug 26, 2008 | 04:05 AM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
I noticed more throttle response.Also the engine sounds way better in my opinion when you floor it.
Old Aug 26, 2008 | 06:50 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
i didn't notice an effect one way or the other on fuel economy. I do have more power, especially high-end, but heres the deal:
If you live someplace hot like me (Georgia) you may actually loose low end power in the summer.
My low end got a little sluggish but my 3500-5500 performance improved. When it is cool out my performance and throttle response iimproved across the board. My car also runs hotter in the summer now due to the higher intake temps. All in All I'd say go for it.
Old Aug 26, 2008 | 07:03 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i run a L69 w/ a really big filter that exposes the top 2" of the filter. Found it worked better. Also just getting rid of the drop base and spacer helped too. MPG not a big difference but over 3000 rpm a good change. I will later hook up hoses to the intake but have failed to find one that fits.
Old Aug 27, 2008 | 12:49 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
talking about the vacuum hose for the air inlet warmer ?
Old Aug 27, 2008 | 10:38 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
I forgot about mentioning that. My engine had a much meaner sound! I love it! I understand that the OP was asking about MPG but I still say worth it for other reasons. I got mine at Advance for $12, 9" by 3" chrome
Old Aug 28, 2008 | 12:54 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
I already have a 14 inch in my garage
Old Aug 28, 2008 | 09:53 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Wrong place for it!
Old Aug 30, 2008 | 12:10 AM
redsoxsuck9095's Avatar
Car: 90 camaro
Engine: 305 tbi
Axle/Gears: stock
live in se mass. Drive car only in summer. Got Everything apart from the intake up. any sugesstions on what to do while its aprt.
Old Aug 30, 2008 | 12:48 AM
GMLSX's Avatar
Car: 1998 Slow
Engine: Too Small
not to be rude, but for starters, start your own thread instead of jacking this guys...and we will all be more than willing to input things to do...make a new thread and we shall talk.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
wruiz
Aug 13, 2015 09:07 PM
