Idling problem
Old Aug 26, 2008 | 02:35 AM
89Limited's Avatar
Car: 89 Bandit, 88 formula, 87 Trans Am
Engine: 305 ho, 355, 305
Transmission: 700r4, th350 (2000stall), 700r4
Axle/Gears: 2.73, 3.73, 3.73
Idling problem
a lil background n the car, it s a 89 Bandit car with less than 86,XXX miles. it is a 305 TBI w/ 700r4. I gave it a tune up (plugs, wires, cap, button, fuel filter) and now it wont idle. itll catch at startup up, rev like normal then just die. if it catches its self from dying, its rev and attempt to die over and over. if i give it some gas itll either stutter or die. any attempt to drive it fails miserably. i installed everything, went to start it and now it runs as previously stated. it ran fine before the tune up. any ideas?????
Old Aug 26, 2008 | 03:36 AM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
Re: Idling problem
Maybe you tweaked your timing or didn't put your Cap, Rotor on Properly?I would double check everything.
Old Aug 29, 2008 | 11:47 PM
89Limited's Avatar
Re: Idling problem
chased down the problem, jumped a tooth on the timing
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
