Running rough
Old Aug 31, 2008 | 06:20 PM
kenwa26's Avatar
Running rough
I just picked up an 89 camaro that originally had a 5.0/m5, now has 5.7/m5 runs very rough, lacks power and shows codes 33 and 45, i replaced the map sensor and it seems to run a little better, had a very bad stumble, but still is nowhere near what it should be. its a tbi setup, any thing you guys can think of might help?
Old Aug 31, 2008 | 06:38 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: Running rough
Give all the details, is this an L05 motor? Or just a 350 that you swapped over the stock 305TBI stuff onto?
Old Aug 31, 2008 | 06:40 PM
kenwa26's Avatar
Re: Running rough
I didnt do the swap, i literally got this car 7 hours ago, im thinking about telling the guy i have changed my mind and want the motorcycle i swapped back. I will get the numbers off the engine.
Old Aug 31, 2008 | 06:44 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Running rough
Yeh, ask the guy all the information. Maybe its using the wrong injectors, or the wrong ecu
Old Aug 31, 2008 | 07:09 PM
kenwa26's Avatar
Re: Running rough
Yeah the guy I got it from got it from the guy who did the actual swap, supposedly it ran fine, but im not really beleiving it, im 100% confident I can get it running properly, but I traded a perfect good motorcycle for it, and i didnt really want something that would need a lot of work, the only other info I have is that the engine came from a 90 truck.
customblackbird
Aug 15, 2021 10:16 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
