tbi on carb intake
Old Sep 15, 2008 | 12:46 AM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
tbi on carb intake
Iv searched here before asking. A friend of mine has a 88 camaro with tbi iv learned that if you get a adaptor plate you can run almost any intake out there (just about) here comes the Q, plans are a LT1 cam, hedman shorties with already 3in not cat exhuast, ported heads on a 305, what would be the best intake to use? I'm a tpi guy so this is all new to me. I don't understand single and dual plane, if anyone can help thanks.
Old Sep 15, 2008 | 03:57 PM
robert1's Avatar
Re: tbi on carb intake
You'd want a dual-plane for sure. It has two "levels" of runners, for each side of the engine. It basically adds runner length, for more air velocity, hence more torque. That's how Holley did it years ago with the first add-on TBI for any engine. They just had an adapter plate. I went to this many years ago, and have never gone back to a carb yet!
Old Sep 18, 2008 | 02:01 PM
mike85's Avatar
Car: 89 camaro rs, 86 iroc-Z, 05 cbr900r
Engine: 305-383
ok no need for my new post, so you can use a tbi on a carb intake? what is a good budget friendley intake that will work? where do I get this adepter plate, I have been searching... and any certin type of intake it has to be? all info welcome!!!
Old Sep 18, 2008 | 04:09 PM
Triaged's Avatar
http://store.summitracing.com/egnsea...=KeywordSearch
http://marine-performance-parts.com/...keadapter.aspx
http://marine-performance-parts.com/...bblintake.aspx
Old Sep 19, 2008 | 09:17 AM
Ronny's Avatar
I bought a .25 inch plate from Howell Engineering. they specialize in retro TBI fitment kits for carb cars
Old Sep 19, 2008 | 07:02 PM
Car: 86 Iroc-Z
Summitracing.com has one from painless for about 95bucks. I did a search on google and found some as low as 40bucks. And as for intake read above makes sense but it also has to do with your engine setup too. If you want higher rpm then single but if you want tq then dual plane. There aren't really cheap intakes out there except used, the edelbrock air gap is pricy but works. You have to remeber if your motor is 87up 305 or 350 you need to look for that intake that's spcified otherwise any intake will bolt on with the right adaptor plate. I think there's one for a holley to quadrajet style intake and vise versa
Old Sep 21, 2008 | 07:37 PM
mike85's Avatar
Engine: 305-383
its getting there now!! thx guys!!I got the edelbrock RPM air gap, 229.00(nice intake) diff is between idle and 5500 rpm...And very noticeable!! I will soon update pics. I got the adapter plate from the link above..thx for that.. well everything came from summit and very pleased.. so again, thx everyone!!! lets start rebuilding the rear end now...
Old Sep 22, 2008 | 12:55 AM
Car: 86 Iroc-Z
Good job hijacking the thread buddy(just playin) glad to hear it worked out good. Did you have to retune the ecm? Rear end would have to be 12bolt but that's my opion others will say ford 9 but search and see what best suites you. Good luck
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
pimp2303
Jul 27, 2017 02:03 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
theurge
Aug 21, 2015 12:46 PM
