electronic or fuel problem?
Old Oct 1, 2008 | 08:21 PM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
car runs for about 2 seconds then dies. I unplugged the coolant or temp sensor located next to the thermostat on top front of the motor and it ran fine but at a real high idle. thought sure that was my problem. installed a new sensor, plugged it back end but car only ran for a couple seconds. I unplugged the sensor and car ran fine again but real high idle. I decided since the car was running now I could take it to the shop. I started it once more with the sensor disconnected to see how long it would run before I got out on the road. It did run for 3 minutes or so at high idle but then died and now with the sensor plugged or unplugged it will just run for a few seconds. The battery was bad and I replaced it but still the same problem. I also changed the fuel filter. It the fuel pump is bad I would not think it would have run for the 3 or 4 minutes or so. Need help, would like to take it to Cruising the Coast next week.
Old Oct 2, 2008 | 09:25 AM
CamaroRider's Avatar
Re: electronic or fuel problem?
I would suggest you start by actually measuring your fuel pressure. Otherwise you could spend lots of time and money changing parts you do not need. It is always great to be able to observe your actual fuel pressure and state 'It is definitely not a fuel pressure problem'.
Old Oct 9, 2008 | 10:41 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Measure the resistance of that new CTS. It should be ~2-3K ohms cold and only about 200 ohms at 200 degF. You may have purchased a bad unit.
Old Oct 10, 2008 | 02:07 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Every tbi guy should have a fuel pressure gauge. May be the fuel pump or like in my situation, a bad rubber fuel line in the tank. They get old and split. Mine was like mush went I took it out.
Old Oct 14, 2008 | 09:51 PM
reaper_Z28's Avatar
Car: 89 RS
Engine: stock TBI 305 atm
also check the oil pressure switch and relay. the relay will allow fuel without oil pressure for only a short period to enable startup, but once it is running, it will kill the fuel pump if it doesn't sense oil pressure after a few seconds.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Fast355
Dec 2, 2016 06:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
