Why is it bad if distributor is "off a tooth" ?
Old Oct 27, 2008 | 09:27 AM
Big6ft6's Avatar
You often see people saying, "yeah, I fixed the problem...my distributor was off a tooth".
Wouldn't one be able to put the distributor in anyway one would like and simply adjust the cap left or right to get proper timing? As long as the rotor strikes the #1 contact when the #1 cylinder is at TDC, who cares what the orietnation is of the actual distributor?
Am I missing something?
Old Oct 27, 2008 | 12:01 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Why is it bad if distributor is "off a tooth" ?
Usually the ignition wires or the spark plug wires connected to the cap prevent you from turning the cap far enough to get proper timing.
Old Oct 27, 2008 | 12:07 PM
Big6ft6's Avatar
Ahhhh....got it. That makes sense, so I had the "theory" right...I just had the "in practice" wrong.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
