Newbie: 83 Z28 305 Cross Fire (2) TBI - Fuel Filter?
Old Nov 12, 2008 | 12:36 PM
dford's Avatar
Hello,
Is there a fuel filter on this car? We couldn't find one when we replaced the fuel pump.
Also, Are the injectors sposed to feed a contant jet of fuel or intermitent like a sprinkler?
One more, Fuel line on the passenger side was loose.... rubber hose on a high pressure system. Is this normal?
Thanks.
Dan
Old Nov 15, 2008 | 12:55 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Newbie: 83 Z28 305 Cross Fire (2) TBI - Fuel Filter?
The fuel filter is located in a bracket on the front passenger side of the engine block where the mechanical fuel pump normally is on carburated cars.
The Cross-Fire is a low pressure fuel injection system. It only runs around 13 PSI so it uses standard hose connections.
Old Nov 15, 2008 | 02:51 AM
dford's Avatar
Thank you. Found it but the rubber fuel hose is very, very short. Typical?
Dan
Old Nov 15, 2008 | 07:18 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Dford the short rubber line was meant to provide a flexible connection between the feed line and the block mounted filter. Sometimes people will trim a bad end instead of replacing the entire section of hose. I replaced mine with high pressure hose just for added insurance. I also relocated the filter from behind the alternator (great location..LOL) to the right frame rail. Also in the future I want to upgrade to a TPI pump with regulator.
The injectors do cycle but to the naked eye the appear constant. The fuel spray should be cone shaped. The CFI injectors are a bit noisy when operating properly - sounding somewhat like a ticking lifter.
Dens71TA is correct the factory gives 9 -12psi operating range for the system. This is similar to a "normal" TBI system. The front TBI has a compensator with the actual regulator in the rear TBI unit. The system actually likes 14 -30psi to operate properly.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
