where is the IAT Sensor located?
Old Nov 18, 2008 | 06:37 PM
TampaBowtie's Avatar
on an 89 350 TBI? Is it the thing with 2 wires going into it. And it has the vacuum line on it that leads to the throttle body
Size:  56.5 KBName:  DSC_0120.jpg
Old Nov 18, 2008 | 08:00 PM
Re: where is the IAT Sensor located?
pics posted again.
Old Nov 18, 2008 | 09:47 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Pink/black and light gray wire connector are used for EGR control valve.
//RF
Old Nov 18, 2008 | 09:55 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I dont think there is one on a TBI.
Old Nov 18, 2008 | 11:08 PM
RFmaster's Avatar
Car: 75 Beast
Cars (camaro and B-body) used IAT with 8746 and 6965 ECM's respectively.
TampaBowtie photo is of TBI truck (7747) which uses mounting plate-bracket to mount ESC, ECVS and MAP. IMHO, I do not like to have my electronic components mounted on top of a hot engine, but GM thought otherwise.
In case of a truck TBI (7747) there is no IAT.
//RF
Old Nov 19, 2008 | 02:30 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
i think on the tbi firebirds the IAT is located inside the base of the air cleaner, in case you have the stock one. i dont see any point in having a vac-connector on an IAT.. pretty sure about that. imho many people with an open element forget to hook these sensor up again.
Old Nov 19, 2008 | 09:11 AM
well mine has a ton of sensors on it. and i think it is the one right next to the one with the 4 wires. but it has the tan and red wire.. but i am not sure and it is under the base of the air cleaner as well. And there is no where to insert the vacuum hose in my air cleaner
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
