service engine codes
Old Dec 4, 2008 | 11:13 AM
92yellowcamaro's Avatar
Car: 1992 camaro rs, 1988 saab 900
Engine: 305 tbi 5.0L V8
does anyone have a list that tells what all the flash and pauses codes are?
like flash pause flash flash is "12" is their a list that shows all the combos?
thanks
Old Dec 12, 2008 | 08:48 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I KNOWED DA KODE
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Manifold Absolute Pressure Sensor Circuit (High Sig.)
34 Manifold Absolute Pressure Sensor Circuit (Low Sig.)
42 Electronic Spark Timing (EST) Circuit
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 Faulty PROM
54 Fuel Pump Circuit (Low Voltage)
55 ECM Error
Happy Racing!
- Race Clean!. . . . . . . . . . . Do It On Dirt! -
Old Dec 12, 2008 | 11:24 AM
Ronny's Avatar
Re: service engine codes
I would think most full service auto part stores can link diagnostic tester to ALDL and do for free.
Old Dec 12, 2008 | 11:30 AM
Stephen's Avatar
Car: 87 GTA
But you don't need a parts store...You just need a paper clip, or short length of wire.
Autozone has a "key", but it is really just an uncut key, with 2 prongs. My local Autozones give them away all the time.
And code 12 is "All Clear, No Errors)
Look on..... Error Codes The codes are there.
Old Dec 12, 2008 | 11:48 AM
Ronny's Avatar
Yea but the blinky lights drive me crazy. Their diagnotic tool reads out in words not blinks..
Old Dec 12, 2008 | 11:54 AM
Stephen's Avatar
Car: 87 GTA
Nope...Not on OBD1 systems they can't. All they can do is blink the lights & read too.
Only on later OBD systems does it read in words.
Old Dec 12, 2008 | 12:16 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Correct, the GM "code module" they sell at checker is pretty much 2 connectors that plug into the ALDL and its serves the same function as a paper clip, causes the SES light to flash a series of codes.
The only exception where OBD reads in word is on a Tech1, for some ungodly reason my instructor has 5 of the ancient things.
Moral of the story, unless you want an archaic tool laying around, use a paper clip, stick it between the 2 terminals, watch the lights and count em up
Old Dec 12, 2008 | 01:09 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
stephen - you are good. that was a great link! thanks.
Old Dec 15, 2008 | 10:19 AM
NINÅ's Avatar
Transmission: 765R4
OR YOU CAN USE YOUR DECODER RING
No need to fool around with paper clips.
They make hand held code readers.
Just plug it into your ALDL
It will show any active trouble codes, translate those numbers into words, read (independently from your gages) RPM, volts, temps, what your ECM is thinking and much more.
You can monitor performance while you’re driving and look at it real time or record it to look at it while stopped.
Happy Racing!
Old Dec 15, 2008 | 10:29 AM
Stephen's Avatar
Car: 87 GTA
Re: OR YOU CAN USE YOUR DECODER RING
Not for OBD1.....All a consumer can get is the flashing codes. NO real-time data is displayed. Use the paper clip or "key".
Old Dec 15, 2008 | 10:41 AM
Ronny's Avatar
This is prob the most common code reader for OBD1
Actron CP9001 GM OBD I Code Scanner $35 ??
But as stated the paper clip is more cost effective
Old Dec 15, 2008 | 11:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sure there is, the MPSI-9000 hand held scan tool I paid $75 for years ago reads out the codes in plain English. Such as:
33 MAP SENSOR HIGH
And provides real time sensor data. You can read/see items such as the engine RPM, vehicle speed, MAP value in voltage and KPa as the engine is running.
Not sure why you don't think that ODBI can do this. GM systems have been this way since the advent of CCC setups.
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
