305 tbi to 350 carb
Old Dec 5, 2008 | 02:27 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
305 tbi to 350 carb
i have a 305 tbi but im getting a 350 with a carb but i want to transfer my tbi intake and throttle body on the 350 what has to be dont for it to work right?
the motor used to be a tpi but it got swapped to a carb now i want it back to tbi.
thanks
Old Dec 5, 2008 | 03:15 PM
Heslekrants's Avatar
Car: 1990 Camaro RS
Engine: 5.7L Vortec TBI
Transmission: Built 700R4 2800 stall
Re: 305 tbi to 350 carb
I just completed a 305 TBI to 350 TBI swap.
As long as your 350 is an 87-95 block your intake will work with no issues.
What you need are:
* 350 ESC module - GM 16128261
* 350 knock sensor - GM 10456288
* 350 injectors - Best if you can get the injectors & ECM from 89-90 Caprice Cop car but standard 350 injectors & ECM will work.
* 350 ECM - Get a custom chip programmed for your ECM or use a chip/ECM from a 89-90 350 TBI Caprice.
My 90 Camaro had the same 8746 ECM as the 89-90 Caprice so I only needed to change the chip. What ECM dose your 91 have?
Old Dec 5, 2008 | 03:22 PM
Car: 1991 Trans Am
Axle/Gears: Stock
ok cool thanks but where can i find a old caprice cop car lol and where can i get the knock sensor (where does it go)?
thanks
Old Dec 5, 2008 | 04:39 PM
Car: 1991 Trans Am
Axle/Gears: Stock
would these injectors work?
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__GM-5-7-350-TBI-Fuel-Injectors-Pickups-Vans-Caprice_W0QQitemZ250333631395QQadiZ2865QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item250333631395&_trksid=p4506.c0.m245&_trkparms=72%3A1194|65%3A12|39%3A1|240%3A1318
Old Dec 6, 2008 | 08:42 AM
Car: 1990 Camaro RS
350 knock sensor - it screws into right side of the block near the starter.
Here's some info I found on another website. The ESC is found on the firewall somewhere. The ESC & knock sensor should be $5 or less items at your local junk yard but spendy to buy new.
Here is what the ESC looks like. It interprets the knock sensor signal so this needs to be changed.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
92purpz28
Aug 11, 2015 02:30 PM
