Someone please help!!!
Old Dec 10, 2008 | 11:45 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
OK so i had this posted in the tech / general engine section with no success. I am hoping that posting it here someone might know what problem i have. Here is a link to the posts https://www.thirdgen.org/forums/tech...ssing-wot.html
Also here is a video of the problem i am having http://s495.photobucket.com/albums/r...Carproblem.flv
This is my D/D so i am really in need of having her up and running again. Any response, reply, suggestion, ANY help is greatly appreciated -Russ
Old Dec 10, 2008 | 05:27 PM
Engine: 5.0 TBI
Re: Someone please help!!!
Ok so should i assume that NO ONE knows what my problem could be ? This is driving me !!!!!!
Old Dec 10, 2008 | 06:57 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
You mentioned that you replaced the wires. Is the firing order correct?
Is the distributor in correct? (why is the hood off?)
Old Dec 10, 2008 | 07:39 PM
Engine: 5.0 TBI
I have checked the firing order quite a few times. I achieved TDC by pulling the #1 plug and cranking it over with my finger over cylinder untill it blew off my finger .The car was working fine then all of a sudden she started to miss at WOT, then the problem kept getting worse. As to tell you why my car don't have a hood on..... I just bought the car within the last 4 months. The previous owner hit a Bear on the highway, and destroyed the headlight assembly, upper core support, hood, passenger fender, and last but not least the windshield.
So here I am trying to save this bird from being crushed. I have around $4500 Including the price of the car put into it. I fell in love with F-bodys, when i bought my 99 TransAm in 2000. Then i had my daughter in 2002 , and as soon as she was born i had to sell my Bird .
Old Dec 10, 2008 | 07:47 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
i had the same problem when my egr was opening replaced the solenoid and the problem was fixed. other than that i swa a plugged muffler cause a similar problem
good luck
Old Dec 10, 2008 | 09:07 PM
Engine: 5.0 TBI
I have replaced the EGR valve. That was one of the first things i had to do to get the car to pass emissions. I think the car maybe running rich. I have a rich smelling exhaust that i just noticed.and some blackened snow after i rev'd the engine up.Also my fuel pump has had a whine since i bought the car, but i have never had a lack of fuel issue. Oh yeah for all the replies. Even if i don't have the bird running well right now, i still appreciate the suggestions. - Russ
Edit: also under slight throttle i can rev the engine up to 5000rpms no problem. It's only giving me grief under wide open throttle.
Old Dec 13, 2008 | 06:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you hooked up a fuel pressure gauge yet?
Old Dec 13, 2008 | 06:32 PM
Engine: 5.0 TBI
I have not yet. I don't have acess to one right now. I do have a air/fuel gauge to install to see atleats if i am running rich or lean. I have an idea that i may be running lean at WOT. If my pump is going out it would be loosing pressure and causing a lean condition at higher rpms. I also have a Holley 12-903 255lph pump to install over the weekend.
Old Dec 13, 2008 | 11:24 PM
zchevy2's Avatar
Car: 82 camaro
Engine: 383 strocker
Transmission: th350
try setting your base timing up 4-8* any modified tbi seems to like that it will even help a stock one. also before u spend another dime check your fp anything less than 11 psi and they run horrible.
