how to make my car faster
Old Dec 11, 2008 | 01:50 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I have a 1990 camaro 305, how can i make the top speed higher? the speedo only goes to 110, I want the top speed to go higher, how can i do this?
Old Dec 11, 2008 | 03:11 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: how to make my car faster
rs stands for real slow so anything you do will help.
go to tpi from tbi.
hooker 2055 headers with borla cat back.
edelbrock vortec heads.
more cam.
different rear end with posi and 411 gears.
turbo or supercharger.
dump in a 350 - bore and stroke it to a 383 - which is the limits of the tpi from gm.
just about anything you can think of will help. just read the boards and you will see that some of these people have some outstanding rides.
when i was a kid there was a sign at my local speed shop.
"there is no substitute for cubic inches, how fast can you afford to go?
the rule is the same here.
Old Dec 11, 2008 | 03:31 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
I think, he doesn´t want to have more gain. He wants to disable the speed limiter. You need another chip for your ECM with disabled speed limiter. If you cannot burn your own chips, phone or write to Brian from tbichips.com .
Old Dec 12, 2008 | 01:00 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
lucky for me my car is tbi alright, thanks for the tips, but you're being a bit vague, you're saying i should get a cam and heads, and you're also saying i should get a 350, which should i do first? i don't have 2000 dollars in my pocket either.
Old Dec 12, 2008 | 01:30 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
look in the tech article database on this site. it tells you how to wire in a switch to disable the speed limiter.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
