Ported LB9 081 heads vs World S/R torquers
Old Jan 4, 2009 | 10:32 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
Debating here on either getting the world S/R torquer heads or a cheap set of LB9 081 heads and having them ported.
Would ported LB9 heads be as good as the Worlds S/R Torquers? What if i ported the S/R heads, would they then be better then a ported pair of 081's?
Old Jan 7, 2009 | 11:16 AM
Ronny's Avatar
Re: Ported LB9 081 heads vs World S/R torquers
I would not bolt on the World heads unless I first ported them. Dart makes a small chamber iron head($660/pair) at 49cc but I suspect that may be too small for a 305cc. Not sure if a thicker gasket would make it work. Something tells me Dart will out flow either choices by quite a bit.
Old Jan 20, 2009 | 05:54 PM
Rutru9415's Avatar
Good health
bump up ..If you need sell cheap wow gold,you can buy wow power leveling on the website: buy wow gold, cheap WoW Power Leveling, sale wow Gold, 1-80 lvl wow power leveling, wotlk WoW Gold,
Old Jan 22, 2009 | 03:52 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
go with 081s. I just picked up a set of 601 heads for my engine, Im gunna start the swap this monday night after medic school and hopefully have it back on the road by the following day. I heard they were a set of good heads as well. I had a set that i spent a bunch of time and money into porting them myself only to find they were cracked so word of advice get em checked out before you start any work on them. Plus you can pick up a set of 081s for like 100$.
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
