Best performance airbox/intake system for TBI??
Old Feb 3, 2009 | 04:51 PM
deltaheavy777's Avatar
Hey friends!
Just got an '88 Camaro RS! A bit nostalgic for me, I always love the 3rd gen lines since I was a kid!
-My question is in regards to the best performance air-cleaner system for my Camaro. It's a completely stock air cleaner, it seems like there should be an extended pipe for the airbox that's missing. I am definitely doing a K&N filter, probably with an open K&N air pan. What's the biggest size I can go up to that will fit under the stock hood, would that be the best performing system?
-Spectre performance has a dual intake, cold-air cleaner system as well. Any thoughts on that??
-Doing some shopping this weekend, any suggestions will help! Pretty much, is the K&N open pan system the best or the Spectre cold-air? Or what's out there??
Thanks yall for the help!
Old Feb 3, 2009 | 05:10 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: Best performance airbox/intake system for TBI??
the spectre dual intake dont fit it says it does but it doesnt but then the single pleneum does from spectre thats what i had but i sold it for 60 so you shoud buy this
http://www.jegs.com/i/Spectre/865/98499/10002/-1 (pleneum)
http://www.jegs.com/i/Spectre/865/9719/10002/-1 (straight)
http://www.jegs.com/i/K%26amp%3BN/599/RE-0870/10002/-1 (K&N)
then there you have it a K&N CAI for like 160 thats alot but thats what i did but i didnt have the K&N i bought a cheap 20 filter lol
Old Feb 3, 2009 | 05:48 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Currently running a Mr. Gasket open air element air cleaner 14" ($25) and bought a K&N 14"x3" ($50), went to home depot and bought a threaded rod to fit the tb base and bent it slightly to curve like the stock tb pole, and cut the tip ($1.99), this ran me about $80 at the end, for an open air element air cleaner. Cheap and does what it needs, i'd recommend it, but its really your chose. I wouldn't spend like $75 for an eldbrock air cleaner or anything to name brand for a high price, honestly mine does what it needs and i saved a bunch. but like i said your chose, need pictures i'll supply to give a better idea.
Old Feb 4, 2009 | 10:28 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Think you could convert a Spectre Bonnet down to a tpi air box?
Old Feb 4, 2009 | 10:52 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I've always run an L69 dual snorkel setup...not sure if this is considered good or not but I would think it's better than sucking hot air with an open element (I do a lot of low-speed city stop n' go stuff) and it can't be any worse than the stocker.
Old Feb 5, 2009 | 06:05 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I modified a spectre intake to fit on a Ford Torino.. Bolted it to a 2X6 piece of wood and clamped it in a bridgeport.. Took off 1/2" of material where it goes on the carb and now it's perfect..
I'm running an Edelbrock base, 14" paper airfilter and a 14" K&N breather lid. You can hear it sucking air, loud as hell.
MustangBeater20
Oct 29, 2022 09:20 PM
Keith5
Aug 27, 2015 04:37 PM
zayne0
Aug 24, 2015 07:22 PM
Randomtask2
Aug 13, 2015 01:57 AM
