TPS and IAC adjustment???!!!???
Old Feb 7, 2009 | 07:30 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
got a new TBI with a new TPS and IAC
the TPS can be adjusted and looks like this
what the proper wat to set it, i pretty much moved it back and forth the the idle got right
also how do you reset or set up the IAC or is there such at thing
Old Feb 8, 2009 | 02:54 PM
89RS_82Z's Avatar
Re: TPS and IAC adjustment???!!!???
Old Feb 8, 2009 | 05:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ECM auto-zero's the TPS value. As long as it is between .4 and .9 volts at idle it'll work. Can check the voltage with a scan tool or back probing with a DVM. Engine can be off to do it.
For the IAC, it will auto-reset after the engine has been running and the key is switched off. Just fire up the engine, blip the throttle for the heck of it, when it returns to idle turn off the key. Wait 5 seconds or more and the IAC is reset.
RBob.
Old Feb 10, 2009 | 04:27 PM
Ronny's Avatar
Be aware some TBI units have a specific base gasket. It must seal the IAC valley or massive vac leak. When unit on manifold or adapter there but be gasket visable at perimeter of TBI. Mine I think is about .125 inch overhang.
Old Feb 11, 2009 | 06:56 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
see on my 91 there is a "feild service" adjustment for the iac. I forget the exacts on how it works but it closes the iac to adjust base air flow
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
86IROC112
Nov 27, 2015 09:54 AM
L98GTA87
Oct 19, 2015 10:43 PM
Fred SS
Oct 12, 2015 11:27 AM
