surging idle/constant RPM
Old Feb 7, 2009 | 07:34 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
look at this vid, to pretty much explain it
<Car Stats there and also in vBgarage
any idea on how to solve this
im holding it at 2k then at other RPMs
http://www.youtube.com/watch?v=PrwnyKGNkOU
Old Feb 8, 2009 | 02:59 PM
89RS_82Z's Avatar
Re: surging idle/constant RPM
Old Feb 8, 2009 | 05:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If I had to guess, which is mostly all that I can do over the 'net, is that there is a vacuum leak. Good possibility it is the gasket between the TB and intake manifold.
The reason I say this is that after the throttle is punched and the engine returns to idle there is a whistle sound (from about 37 seconds on to the end). I've found this to be either the TB base gasket has dried up and is leaking or the air cleaner assembly has been changed.
As for the air cleaner set up for some reason non-stock setups can cause a whistle. Not sure why, just that they can.
RBob.
Old Feb 8, 2009 | 06:04 PM
89RS_82Z's Avatar
i dont have a stock breather, and i think i had it off on that vid....
it may be the gasket, but its new so im not sure, i need to hook my vac gauge up and see what im running in vac, see if its a little low
what whistle my be that power master alt also, idk why but all power masters seem to be a little louder than stock alts
Old Feb 9, 2009 | 04:22 PM
89RS_82Z's Avatar
BUMP!!!!!!
Old Feb 10, 2009 | 12:20 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
had a similar issue, i would say a vacuum leak somewhere, try pulling codes too, my problem was a bad MAT sensor.
Old Feb 10, 2009 | 04:16 PM
89RS_82Z's Avatar
grrr can find a vac leak anywhere BAH!!!!!!!!!!!!!!!!!
lol i will pull the codes later tonight i hope
Old Feb 11, 2009 | 11:43 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
honestly it it sounds alot like mine did after I did the tbi mods and headers and all. I ended up haveing to set the comp into the feild service mode. use the jumper for the check engine while runing and back the throttle stop off a little. but mine also stumbled when in gear though
Old Feb 12, 2009 | 08:34 PM
89RS_82Z's Avatar
mine is stumbling at high rpms, so you put it is field service and set the idle screw???
Old Feb 15, 2009 | 04:42 AM
Triaged's Avatar
My 2.hate S10 did that to me once (right at the same RPM). It was a hairline crack in the ign. coil. It would have been easy to spot on a scope but I don't have one. I popped the hood open at night and watched the little purple ants jump around on the coil.
Old Feb 16, 2009 | 12:59 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Are the pcv/breather valves in the valve covers in decent condition still ?
Is the TBI unit crusted on the bottom in the sunken valleys?
Old Feb 16, 2009 | 03:16 PM
89RS_82Z's Avatar
PCV is new, crankcase breather is new, TBI is brand new...... i cant figure out why its doing this for anything.....all i can figure is the ing module, since it breaks up at high rpms to
Elephantismo
Feb 13, 2019 12:51 AM
92camaro350cci
Oct 14, 2015 09:29 AM
wisemanz28
Sep 20, 2015 01:26 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
