Budget Help
Old Feb 13, 2009 | 05:52 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Budget Help
No numbers for pricing on budget but lets just say a bit moderate or as cheap as possible. I'm looking to go a bit mild with my block. I run a 305 tbi currently and just looking to go a bit more thats all. If anyone could supply me a list with some parts for a build, nothing major like pushing 400+ hp and tq but a bit more than stock thats all.
regards,
Timinsk
Old Feb 14, 2009 | 04:12 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: Budget Help
you should set a goal (whp or hp), you're just saying you want less than 400hp, but 390 is also less
also be aware that most mods will require you to re-tune your ecm which can cost a lot of time for first timers (including me) and further equipment such as a wideband o2 sensor + controller and gauge, or upgraded ecm (EBL).
for starters, be sure to uncork that bloody wimp of a stock exhaust GM put on these cars. get headers like the hooker 2055 (includes y-pipe), 3" highflow cat and exhaust. you will also need to upgrade your fuel pump for later mods. if you're keeping your stock heads (depends on your goal), exhaust will imho be the most costly section in your build.
hth
Old Feb 14, 2009 | 06:28 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Budget Help
exhaust, and air cleaner already done mostly, just seeing what I could do for just mild upgrades from my stock engine. Lets just say then i was more than stock specs for hp/tq to about 250-300 hp/300-400tq if possible, i dont know if any small parts would give such a critical change, i was looking into maybe just heads and camshaft thats all, nothing drastic for lift just something to keep my current gas mileage or a bit better w/ better performance thats all, im 18 yr old with a pt job lol lets think of the budget that way :P
cheesehomer
Dec 31, 2015 08:48 AM
Jorlain
Oct 8, 2015 01:57 AM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
