JY Hunting
Old Feb 23, 2009 | 08:06 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
JY Hunting
Any curtain parts I could find at the JY (don't worry I find good condition parts) that would be cheap and swap into my 305? Trying to do a budget build but thought it might be easier to get something from a JY than online, i know new is a nicer idea but i can't be spending so much on a budget honestly... Trying to pull as much power without having to spend that much..
Old Feb 23, 2009 | 12:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: JY Hunting
If you find an LT1 in a f-body the cam would be worth pulling and installing in your 305.
RBob.
Old Feb 23, 2009 | 01:59 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: JY Hunting
hmm sounds good, if i get that, would my stock parts still run sufficiently?
Old Feb 23, 2009 | 05:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: JY Hunting
Most likely need to do some tuning. But this is true for any parts that change the VE and SA requirements of the engine (heads, exhaust, cam, ...).
Or, did you mean that you can still use the same push rods and lifters? Yes, as long as they are in decent condition they can be used with the LT1 cam.
RBob.
{edit: there is an 'LT1 Cam Digest' in the sticky's. I would read it for this swap.}
Old Feb 23, 2009 | 07:47 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: JY Hunting
ah ok, because i dont have the money to be buying new heads thats why, and i dont mind if i could buy a different cam and swapping it if i could still use my stock internals while still gaining.
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
bbsr72
Apr 2, 2016 09:12 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BDR
Nov 7, 2015 03:05 PM
89newfun
Sep 16, 2015 09:28 AM
