T-5/3.08 guys...what's your RPM at 75?
Old Feb 26, 2009 | 12:33 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
My tach claims 2,400 RPMs at 75...is that true? Seems kinda high to me for 3.08 gears...I highly doubt my rear end has different gears in it. I have a 3/90 Motor Trend road test of a '91 RS, that showed 60 MPH at 1600 in the spec chart...mine shows 2k at 60.
Any help is appreciated...I assume my tach is off?
Old Feb 26, 2009 | 02:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
We ran the math in our pit laptop and it matches Motor Trends’ numbers.
If parameters =
3.08
.7 OD
27” tires
1610 RPM
Speed = 60
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 26, 2009 | 05:22 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: T-5/3.08 guys...what's your RPM at 75?
Im about 2200-2400 to but my car just cruises fine at that speed but im also on stock 16 rims with 50 profile tires
Old Feb 27, 2009 | 08:27 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Your tach is off. So is mine, so I made a spreadsheet of my rpm vs speed. Here is yours and I guessed on your tire size. I can email the spreadsheet if you want it.
Old Feb 27, 2009 | 04:19 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
calebzman,
can you upload this spreadsheet as a picture by changing its extension to jpg?
could be helpful for a couple of us. thanks
Old Feb 28, 2009 | 11:52 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I don't know if that chart applied to autos too, but I cruise at 70 mph doing about 1550 rpm.
Old Feb 28, 2009 | 11:56 AM
kcb37's Avatar
My tach says 2750 at 75. That's how I judged my speed on the interstate, cause my speedo dosen't work.
I don't know how accurate my tach is though either. That's also with my GPS at 75 MPH.
Old Mar 2, 2009 | 11:29 AM
Jason E's Avatar
Could you email it to me? That'd be great! jasonfivestar@hotmail.com
I'm using 245/45/17 BFGs at the moment...could that have something to do with it? Based on having other cars clock me on the highway, I know the speedo is accurate. I figured the tach was off...it seems like it gets to 3k in first gear a little on the quick side Is there any way to re-calibrate a stock tach? Thanks...
Old Mar 2, 2009 | 12:17 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Originally Posted by ownor
calebzman,
Here ya go. It's saved as a .doc file extension, so after you save it to your harddrive, change the extension back to .xls and it will open as an excel file.
After that you can modify the tire size, rear gear, and transmission parameters to match your current combo. It's also helpful to see how a different tire size or rear gears will effect speed.
File Type: doc
Old Mar 2, 2009 | 12:41 PM
ownor's Avatar
Engine: LS1 / L03
thanks a lot for the spreadsheet!
if you are changing tires, you will need this site to determine how much off your speedo will be compared to the stock tires
http://www.miata.net/garage/tirecalc.html
based on this, you could change the speedo gears in your trans to correct it
OR
you can use another link to check for tire alternatives and find out which ones you can use without having to correct your speedo:
http://www.dsm.org/tools/tiresize.htm
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
