Fuel pressure drop
Old Mar 18, 2009 | 12:02 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Fuel pressure drop
Today I got my fuel pressure regular modded and turned the FP up to 15PSI at idle but I notice that when I give it gas with my hand standing there so I can watch the gauge it drops down to only about 9PSI, is the initial drop normal and it will build back up after a second or so or is it a sign of the pump not being able to keep up with the demand? Also is a TPI pump a sufficient upgrade or do I need something more?
Old Mar 18, 2009 | 01:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel pressure drop
There isn't enough fuel delivery. It could be a clogged filter, if not then the pump can't handle the flow at that pressure.
A TPI pump is OK. Not knowing the HP level can't say whether it is enough pump or not. Note that at 15 psi it will be flowing a lot more fuel then at the normal 43 psi of a TPI system.
When you do the throttle blip test the fuel pressure needs to remain rock steady.
RBob.
Old Mar 18, 2009 | 02:12 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Thanks RBob, the fuel filter is brand new so I guess that means its a weak pump. With the old cam and a 750 Double Pumper the motor made just shy of 400hp at the wheels in my TA without spray. No N2O on the truck though. Man I wish I wouldn't have flipped that car.
Old Mar 18, 2009 | 03:18 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Could also be the FPR spring being too weak.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
