advice and combinations
Old Mar 29, 2009 | 09:04 PM
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
Axle/Gears: 4th gen with 342's
Old Mar 30, 2009 | 12:06 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: advice and combinations
Originally Posted by heavyduty
I am hoping for some fast advice on the motor i am building for my 94 suburban..i gave up on the vortec engine idea and have a virgin 3638 marine block with 810 heads with the big valves...i have done countless searches on cam and intakes combo's but i am pretty much staying stock and shooting for fuel mileage. i am putting an edlebrock performer RPM intake with a transdapt plate on and some 1.5 roller tip rockers i have..its a roller block but it has a flat tappet cam..my question is 1. should i stay with the cam thats in it ? 2. if i can find a factory roller cam out of another 350 tbi motor would it be of any benifit? 3. i have access to a vortec cam/lifters etc to put in my motor.. i am looking for torque to move this heavy thing around...i have noway of doing any tuning on it and wont be able to for sometime to come i am sure..i just need to get this wrapped up..
The 810 heads are swirl port castings, nearly identical to the 193s that should be on your suburban. I ran a F-car LT1 roller cam on the stock tuning in my Van for a while. The B-car/Vortec truck roller cam is even milder. It will give you plenty of grunt for a heavy suburban. I would use the Vortec roller over the cam that is currently in the marine engine.
The 4 center bolt holes on the Performer RPM will need to be elongated to fit the 87+ intake bolt pattern drilled into the heads.
Old Mar 30, 2009 | 01:31 PM
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
so the vortec cam and my computer should get along fairly well? i have machined the holes on the intake for the heads already.. my main concern is keeping the computer happy...thanks fast355
Old Apr 5, 2009 | 11:07 PM
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
Fast...or anyone who can help...i have the vortec cam ready to go...i did notice that the push rods from the vortec motor are about 1 1/2 inches shorter than the ones from the motor i am building...i am not sure which ones to use...i am thinking prob the longer ones because the vortec heads are so much different than the 810's i am running...i would be very thankful for your help...
Old Apr 5, 2009 | 11:17 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Use the pushrods that match the lifter type you are using. The pushrods are not dependant on the cylinder heads. But the roller cam pushrods are shorter than the flat tappet ones.
I also missed the question.
I ran the even hotter F-car LT1 cam on the stock tuning and the computer ran without any hicups. Both cams have a very high, steady vacuum signal that keeps the ECM happy.
Old Apr 5, 2009 | 11:38 PM
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
thanks Fast you have been a great help...i was wondering if you had any idea how much more torque/hp does it add going from the stock combo i had to using the vortec cam roller stuff and a performer rpm intake with adapter ? and beside tuning and headers do you have anyother advice or suggestions?
Old Apr 6, 2009 | 08:33 AM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
A note on the pushrods....
The Vortec heads you'll notice don't use guide plates (they have the 'special' rockers), so the pushrods are not hardened.
If you elect to get guide plates added and go with normal rockers, you have to make sure you use the proper (hardened) pushrods.
Old Apr 6, 2009 | 11:36 AM
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
By "special rockers" are u refering to self aligning rockers? cuz i am thinking most the later model stuff has them...anyways i am running self aligning 1:5 vortec roller tip rockers..after Fast's advice i got to thinking and if i am correct the roller lifter is probably about 1 1/2 inches longer than the standard flat lifter...so thats where the difference in how long they are come from.. i know this is for camaro stuff and the motor that i am pulling from my burban will end up in the camaro...but right now i am determined to get around 25mpg outta the burban...under the right conditions..
Old Apr 6, 2009 | 05:09 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Yes, the self aligning ones.
I just thought I'd mention the pushrods in case you had plans to do things to the heads (like adding guide plates - which would then trash your pushrods), or someone else stumbled on this thread and was wondering.
Old Apr 6, 2009 | 05:26 PM
Irocz_89's Avatar
Car: 1989 Iroc-Z Camaro: Sold :(
Transmission: Built 700r4
I would like to know what is the best Cold Air Intake I can buy for And 89 305 TPI Camaro? And what is the best Super chip/ Performance Chip I can but for it?
Old Apr 6, 2009 | 05:30 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
First thing I'd recommend buying... is your own personal thread (*cough*).
They're cheap, and easy to find, right under the button marked "new thread".
Old Apr 6, 2009 | 08:44 PM
vorticaldavid's Avatar
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
"I ran the even hotter F-car LT1 cam on the stock tuning and the computer ran without any hicups. Both cams have a very high, steady vacuum signal that keeps the ECM happy."
Wait i thought tuning WAS needed when using any LT1 cam?
Old Apr 6, 2009 | 09:21 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not running in a TBI truck 350 it isn't. I adjusted the regulator to 14 psi running the stock AWLD chip in the 299 ECM. It ran GREAT.
The stock hydraulic flat tappet cam in a truck is 194/203 @ .050, .390/.410" lift, 112* LSA. The stock LT1 is 203/205 @ .050, .447/.459, 115* LSA. The Vortec cam is 191/196 @ .050, .414/.428, 111* LSA.
In a 305 F-car tuning IS needed. The factory 305 cam is 179/194 @ .050, .350/.385" lift, 109*LSA and it has fewer cubes.
Old Apr 6, 2009 | 10:46 PM
aahh, now it makes since..... thanks fast
InfernalVortex
Apr 20, 2021 11:31 AM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
