How hard is it to rebuild a TBI unit?
Old Apr 2, 2009 | 02:01 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I just called up Lindertech to get a quote for rebuilding the tbi with a afpr and injector spacer and he told me $350. That is about a $200 labor charge. No way.
So I am thinking rebuild it myself and put the afpr and spacer on. What do I need to know? How hard is it to put the afpr on? I know I need the kit, torque wrench, carb cleaner, and something like tranny fluid to lube the o-rings.
By the way, how do I detach the throttle linkage from the tbi?
Old Apr 2, 2009 | 05:00 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
Re: How hard is it to rebuild a TBI unit?
its not hard to do at all maybe a 2 hour job why your there you should shave the throttle bores. you need silicone lube for o rings, and the throttle linkage is held on by a little clip just use needle nose pliers and pull it off. everything else is pretty self explanatory. just lay it all out on a table and when you take out the screws put them in the hole you took them out of. it looks intimidating but when i did mine i had no background on it what so ever. make sure you use alot of silicone lube or else you will crack your injector pod. i learned the hard way lucky i have three tbi units around.
Old Apr 2, 2009 | 06:24 PM
92 Camaro's Avatar
Thanks a lot. Does the kit come with instructions, or did you follow your Haynes or Chilton's manual?
Old Apr 2, 2009 | 06:54 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
ya it comes with instructions there pretty easy to follow to but the most important thing is keep it organized and clean so you dont mix anything up other than that im pretty sure your set unless anyone else wants to add anything
Old Apr 2, 2009 | 06:57 PM
92 Camaro's Avatar
Did you stick with the stock fuel pressure regulator?
Old Apr 2, 2009 | 07:01 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
ya i just cleaned everything up and shaved the throttle bores all nice and smooth, but it still shoouldnt be a big deal
Old Apr 2, 2009 | 07:08 PM
92 Camaro's Avatar
Alright thanks a lot.
Old Apr 2, 2009 | 07:11 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
good luck to ya
Old Apr 3, 2009 | 08:36 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Are you buying the AFPR? I remember coming across a write up someone had done on here to make your own from the stock regulator. Requires drilling out a small spot weld and tapping the reg. Really easy job to do and costs next to nothing if you've got the tools already. I went this route myself and pocketed the rest of the money to put toward other mods.
Old Apr 3, 2009 | 04:32 PM
92 Camaro's Avatar
No I am buying it. I saw that writeup though.
Old Apr 4, 2009 | 02:39 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Rebuilding a TBI was the first thing I did on my car, way back when I just got it and I didn't know jack about cars. I didn't re-bush the throttle shaft, but did everything else including the FPR diaphragm/spring.
Old Apr 14, 2009 | 04:26 PM
caprice_2nv's Avatar
A TBI should be a lot easier to rebuild than a quadrajet, which I have done with someones help. I'm thinking about rebuilding mine for the hell of it.
What type of things wear out in a TBI and what kinds of problems can they cause? Mine has 305K miles on it and I have most of the service records and it doesn't look like anything has been done to anything in the fuel system.
Old Apr 14, 2009 | 10:12 PM
92 Camaro's Avatar
I have gone a little different route. I am going with a modified unit. But, I still have to basically rebuild it. I just got the throttle body only on today.
Old Apr 19, 2009 | 10:23 PM
92 Camaro's Avatar
I have a question about checking fuel pressure. A good pressure for what I have done so far would be about 13 or 13.5. So, how do I test this accurately? I have an AFPR installed and pictures of my new setup will be up.
Old Apr 20, 2009 | 12:36 AM
Jason89RS's Avatar
I use the actron CP7817 to test the fuel pressure. http://www.actron.com/product_detail.php?pid=16175.
As far as other things to check for on a TBI that has 300k miles, I would have the throttle shaft rebushed for sure. If it is significanly worn it could be a source for a vacuum leak. I would also have the injectors cleaned. Not the put in your tank cleaner, I mean the ultrasonic type cleaning. Since you will have everything apart you might as well make sure the injectors are nice and clean and metering the fuel correctly. I had mine done about six months ago and it cost about $25 a piece at the local carb shop that had the equipment. If you don't have anyone local that can do it I know Turbo City offers the service as well. http://www.turbocity.com/product_inf...roducts_id=563 as well as throttle body rebushing.
Old Apr 20, 2009 | 07:18 AM
92 Camaro's Avatar
Well, injectors have already been serviced, it's a refurbished and modified throttle body, and I have a gauge with the adapter. All is done and I am just wondering about checking the fuel pressure.
Old Apr 20, 2009 | 05:47 PM
92 Camaro's Avatar
All done
Attached Thumbnails How hard is it to rebuild a TBI unit?-008.jpg   How hard is it to rebuild a TBI unit?-009.jpg
Old Apr 20, 2009 | 10:12 PM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
Nice, i bought a 46mm refurbished throttle body for $199 no core charge from xtreme-fi on ebay, I cleaned up the injectors and pod, and put in new gaskets and o-rings, also going in is a AFPR and a gauge with adapter.
High Flow bored TBI throttle body – 590CFM o590 CFM bored 46mm TBI throttle body w/ rebuilt throttle shaft, ultimate TBI modifications
oNew throttle plates, grade 8 (military quality) hardware - throttle blade material may vary from photos
oRebuilt throttle shaft replaces your worn out unit and cures that high/hunting idle
oThis is basically the same unit TurboCity/CFM-Tech sells for $379.99 after core charge (only ours is better and includes more for less money and no core charge
Not a bad deal, what did you set your full pressure too 92 Camaro? personally i dont have a lot of mods done yet so I'll probably set it around 15
Old Apr 20, 2009 | 10:16 PM
92 Camaro's Avatar
15 is too high. actually, you won't even have room to set it that high even with an injector spacer. I tried to set it at 13.5, but I think it was reading just slightly under that even when I adjusted it.
Old Apr 20, 2009 | 11:12 PM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
May be true.
Nothing a TPI fuel pump and some bigger flowing injectors can't solve tho.
But atm it's not really needed, 13.5 should be fine with me.
Old Apr 21, 2009 | 07:16 AM
92 Camaro's Avatar
do you have full exhaust?
Old Apr 21, 2009 | 02:04 PM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
3 inch all the way to the y-pipe.
Hooker 2055's going on soon.
hectre13
Dec 11, 2023 08:14 AM
92camaroJoe
Jul 29, 2023 07:57 PM
hectre13
Aug 26, 2015 08:17 AM
92camaroJoe
Aug 13, 2015 06:07 AM
