How to check cooling fan operation?
Old Apr 4, 2009 | 08:45 PM
Tims91RS's Avatar
I did my 305 to 350 swap and my cooling fan does not want to come on when the car warms up. Is there a way to test the circuit. I tried gounding the fan switch connector. Checked to make sure i was getting 12 volts to the fan relay. Does the pcm control the fan at all on a tbi. The pcm i am using is from a 1990 caprice.
Old Apr 4, 2009 | 10:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: How to check cooling fan operation?
Fan is not controlled by the ECM. It is easy to mix up the fan switch connector and the knock sensor connector. So watch for this.
Grounding the wire/connector to the fan head temperature switch should turn on the fan. Need to do a key-on, engine-off for this to work properly. Then ground the connector center pin.
If the fan doesn't turn on then either it is the wrong connector, the relay is bad, the fan motor is bad, the fan ground is bad, or the power to the fan is bad.
RBob.
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
