Another TBI surging problem
Old Apr 10, 2009 | 05:11 PM
blove78634's Avatar
Car: 88 Iroc
Engine: 5.0 TBI
I have searched and didn't find my problem, so I am looking for your help.
I have an 88 Iroc (LO3).
I bought a TBI rebuild kit from CFM Tech a while ago. Today I finally got around to doing the rebuild. I thought it came apart and went together very easily. I also ground down the "wall section" around the inlets. That came out very well and everything is smooth. When I was done grinding I used my air compressor to blow it out and then used brake cleaner.
Got everything put back in my car and it will surge (900-500 rpms) a few times and then die. The fuel pressure is 9 psi.
Everything worked fine when I took it apart. She ran like a champ.
Thanks in advance for any and all help!!!!
Old Apr 10, 2009 | 06:20 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Another TBI surging problem
Only having 9 psi is your problem. Did you replace the FPR spring or diaphram(sp)? You should have 12 or 13 psi for the L03 if I am correct.
Old Apr 10, 2009 | 06:38 PM
blove78634's Avatar
Car: 88 Iroc
Engine: 5.0 TBI
yes, I replaced all of the seals, o-rings, gaskets and diaphram. I will double check the fuel pressure.
Old Apr 10, 2009 | 07:16 PM
duderjay's Avatar
Car: 88 iroc z28
lean surge is the first thing that came to mind. Watch out when it runs too lean she gets pretty hot in those cylinders.
Old Apr 10, 2009 | 11:53 PM
Engine: 5.0 TBI
I would double check that the diaphram is correctly installed. I have heard if the diaphram is installed upside down it will cause similar problems.
Old Apr 12, 2009 | 08:39 AM
blove78634's Avatar
Car: 88 Iroc
Engine: 5.0 TBI
Thanks for all of the tips.
I double checked my fuel pressure guage (installed in line, in the rubber hose section that is between the hard lines on the wheel well), and it is reading 9 psi. I installed the diaphram with the cup side towards the spring.
When I disconnect the vac. line that runs to the MAP sensor, it will idle constant but high (1100 rpms). I bought a new MAP sensor, when I plugged it in, I still had surging. Trouble guessing at this point.
From what I've been reading, I think my IAC is bad. Got a new one coming soon.
Thanks again for all of the help
92camaroJoe
Jul 29, 2023 07:57 PM
jbd1969
Aug 17, 2015 07:06 PM
92camaroJoe
Aug 13, 2015 06:07 AM
