heated o2 + shorties -> relocate o2?
Old Apr 15, 2009 | 05:10 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hi guys,
i'm about to install my 2055's and i got a heated delco o2 (AFS74) waiting to go in as well, so recently i was wondering if i should use the stock o2 bung in the driver side header or relocate to the y-pipe?
the thing is, i got ceramic coating on my y-pipe + headers and not really too fond of welding a new bung on there.. i'd also need advice about where to put my WBO2
any help and comments are greatly appreciated,
thanks!
Old Apr 15, 2009 | 06:12 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: heated o2 + shorties -> relocate o2?
Both are heated so it doesn't matter, but..
The WB can get cooked. So..
I would put the WB in the Y-pipe.
Old Apr 15, 2009 | 06:34 AM
ownor's Avatar
Engine: LS1 / L03
so you're saying the heated o2 can't be cooked and the stock location is good enough?
i guess there will be enough heat even with the header - so, with the heated o2 i'm just gonna see a slightly earlier closed loop operation right?
oh and about how far away from the collectors should the WB be mounted?
Old Apr 15, 2009 | 07:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would put the WB far from the engine. Under the car right before the cat is good. If no cat then in the test pipe is also a good location (and easy to have a bung welded in with it removed from the car).
Be sure that the WB is mounted so that the sensing tip is on a downward slant.
RBob.
zayne0
Aug 24, 2015 07:22 PM
edfirebird
Apr 21, 2002 07:20 PM
Birmass
May 11, 2001 04:32 PM
Birmass
May 11, 2001 04:23 PM
88blkiroc
Sep 29, 2000 07:15 PM
