Relocate O2 Sensor?
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Relocate O2 Sensor?
Cause my cat is gutted my O2 sensor isnt heating up enough. If i relocate it up closer to the heads in one of the header pipes will that work? Right now its in the stock location on a pair of Edlebrock TES headers. Any other suggestions? It wont idle right unless the O2 sensor is heated properly and its getting annoying having it die at lights. Thanks for the help.
1988 IROC-Z 350 TPI
(its an original 350 car)
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, bored .030 over, Other minor mods
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
Best Time So far: 14.104@99.66 Told you id go faster
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
http://www.suempresaenlinea.com/drowned/images/iroc-black.gif[/img]
1988 IROC-Z 350 TPI
Engine Mods:
Trans Mods:
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)Best Time So far: 14.104@99.66 Told you id go faster
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
They do make 3 wire O2 sensors that have a heating element. Just have to find one that will work with your application.
Illinois has tough emmisions, at least they did when I lived in Chicago.
Get off the gutted cat power trip and put a high flow cat on it. I gutted my cat when it got clogged, and the car smelled aweful. I put a random cat on and the car runs much smoother. Not to mention it would not pass w/o it. It also ran .2 better in the 1/4.
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
Michael Graeber
My Garage
Car: 83 Z28
Engine: 406
Michael Graeber
My Garage
Michael Graeber
My Garage
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hmm i havent had a problem with mine, i also just put headers on it and moved it into the y-pipe
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
86Z "86 Camaro with 88 305 LB9 converted to CARB" that might be why you dont have a problem
Ill check out that three wire one. Thanks
BTW i didnt gut the cat and i can pass emissions without it. I love how it sounds without the cat but eventually im going to a true dual 3inch with h-pipe, random tech cats, borla XR-1 race mufflers. (i have a very secert project in the works, can you say twin turbos???) so ill do the exhaust once i get my projet going. Thanks again
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I got a 3 wire o2 sensor for a 92 ZR1 corvette. It's a widely used sensor because my local dealer (who's probably never even seen a CATALOG of a ZR1) had a bunch in stock. The two white wires to to +12 and ground, and the other wire connects to the current pink wire.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
I know, I shouldn't use this word and the moderators will probably have it on the list of words that will be scrambled but I have been using a "FORD" heated O2 sensor for 3 years now with no problems. It will go right into the Edlebrock headers or you can try a chevy heated O2 which is what I would do if I had to replace it again.
1988 TA 300+hp 350 w/ TBI and Holley TB unit,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
(bought from my dad)
2000 GMC Sierra Regular Cab Stepside
285hp 5.3L w/ 3.42 gears and locking diff. (sold to my dad..no!!)
Originally posted by badbird88:
...I have been using a "FORD" heated O2 sensor for 3 years now with no problems. It will go right into the Edlebrock headers or you can try a chevy heated O2 which is what I would do if I had to replace it again.
BB,
We'll allow you to use the "F"-word on the board, but only if it is used in a derogatory and degrading context. That "Ford" sensor is probably really a Bosch sensor. I'm certain the GM sensor is a Bosch, so it would explain the compatibility (except for the connector perhaps). A chunk of polarized zirconia will prduce the same condutivity regardless of what brand engine it is hung on, so the big hangup is the bung thred size and electrical connection.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Car: Death Mobile
Engine: 666 c.i.
A gutted cat will have no effect on the O2 sensor, only emissions output through the tailpipe.
The O2 sensor is located before the cat. With both my TES and my original exhaust manifolds. Having the O2 sensor closer to the head definitely will make it operate quicker and produce better readings, but the gutted cat has no bearing on it (unless it is clogged and retaining heat, at which point you have a different problem).
eightsixseven
Dec 16, 2024 01:50 PM
ambainb
Apr 25, 2016 09:21 PM
