Idle's way to high
Old Apr 20, 2009 | 05:43 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Idle's way to high
My car when you let it run at constant speed and then come to a stop the car will idle at 2000, if you turn it off and turn it back on it idles back to normal for a while then does it all over again. I have replaced the IAC and clean the TBI religiously since I run with a open filter but this only happens when the car get up to about 150 degrees. When its cold it idles just fine and for about 20min after but when it gets to 150 it starts idleing high and not going back down till I turn it off and restart it. What could be causeing this damn thing to keep doing this?
Old Apr 22, 2009 | 08:49 PM
king1960's Avatar
Re: Idle's way to high
Water temp sensor for the ecm may not be sending correct reading to the ecm. Have you checked you tpi voltage?
Old Apr 23, 2009 | 02:39 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
do you mean TPS? and what voltage should I be getting out of it?
Old Apr 23, 2009 | 06:38 PM
king1960's Avatar
(tps) voltage should be .5volts at idle position and approx.4.2volts at wot. Check with engine not running. Should be gradule increase from ldle to wot
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
