Fuel Pressure/mileage ?
Old May 11, 2009 | 01:48 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
I put in an adjustable FPR and adjusted it to 14.75 psi. My Mileage has DROPPED big time. I assume that backing it down a ways will help but the thing is my engine could use it. So my thinking is that back it down to around 14 psi or so for now. Then when I get my EBL I will be able to dial it in so it is more efficient and not "waste" a bunch of fuel. Would this be correct?
I usually go about 275 or so on a tank, after I'm not even at 200 and down to an 1/8th of a tank. Granted I've been getting on it a little after the adjustment but for the most part keeping habits the same. Any insight or info would be appreciated.
1991 RS 305, cammed, heads, full exhaust, cold air/ram air.
Old May 11, 2009 | 02:28 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: Fuel Pressure/mileage ?
if i calculated that right you're getting about 17-18mpg? that's not too bad in my book.. how much did you get before all the mods? also where are you driving mostly, city/highway?
you can dial in your BPC injector constants in EBL, if you alter fuel pressure these values need to be adapted in the calibration.
also EBL will provide a nice lean cruise mode, along with some other small feats helping you save some more gas
Old May 11, 2009 | 03:35 PM
Car: 91 RS
Engine: 305 TBI
Exactly, that's what I was getting. Now after the FPR adjustment, looks more like 13 mpg. Not good!
Like a dumbass I didn't check the fuel pressure before I adjusted it.
So I don't know what the baseline was before I started adding fuel. I'm afraid of going lean or rich, so where do I error on the side of?
Any suggestions to where I should adjust it to? Or at least start back out at?
Old May 11, 2009 | 04:10 PM
Ronny's Avatar
set it to 12 until you begin tuning and stay away from WOT until you get a tune(EBL). At 12 you will be at stock FP and should be drivable. If car coughs(lean on AE) when you accelerate move it up to 13.
Old May 11, 2009 | 04:22 PM
ownor's Avatar
Engine: LS1 / L03
oh okay, i read that wrong about the milage. 13 isn't that good yeah, i'll agree with that the adjustment Ronny suggested should be fine imho
Old May 11, 2009 | 04:31 PM
Car: 91 RS
Engine: 305 TBI
Stay away from WOT???! What, are you high? Just kidding. I can do that. Thanks for the help guys.
Now if I just had $350 for the EBL.... RBob, you having a sale any time soon??
Old May 12, 2009 | 04:47 AM
Icarus 402001's Avatar
Car: 92RS
What other mods do you have? What rear? With TPI-type CAI, and 3 " catback on an otherwise stock vehicle, I get 23-24 mpg as a daily driver. Routinely go 300 miles on a tank. That's about 40% highway driving. My pressure gauge reads 12 PSI.
Old May 12, 2009 | 09:00 AM
Car: 91 RS
Engine: 305 TBI
2:73 stock rear-end, comp cam, edelbrock headers, 3" exhaust, 99% driving in town. Non stock heads with a port job.
I changed my pressure last night to 12.25. Seems to be running fine so far. Of course I only live about 8 miles from work and it's 45 to 60 the entire way.
Is it natural to have the needle on the gauge wobble a little?
Old May 12, 2009 | 05:27 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
FP should not variate. Your set up sounds like lots of fun once your goin to get the EBL to run it. Keep us updated.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
