I messed up now it turns over but no start
Old May 14, 2009 | 01:17 PM
90fbrdprgt's Avatar
Car: 1990 Firebird
Engine: 305 TBI stock
I replaced the dist cap, wires and plugs but when I hooked the wires back up to the dist cap I put them in the wrong order. So I went to start it and nothing. Put them the correct way and now it turns over but does not start.
Wondering what I need to do from here to get her running again.
Old May 14, 2009 | 01:56 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: I messed up now it turns over but no start
Since you said that you replaced everything back I would check the coil plug wire.
Old May 14, 2009 | 02:09 PM
90fbrdprgt's Avatar
Car: 1990 Firebird
Yeah that is the next step. It was running ok before that so I feel stupid that i tried to do a simple partial tuneup and because I rushed it I screwed it up.
Old May 14, 2009 | 09:44 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Hey that is how you get better! I have learned more from my mistakes than my easy repairs! Some of us get to know firing order and cap orientation by memory from things like this! I am in MN too.
Old May 14, 2009 | 10:10 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i have been known to put the darn things in 180 degrees off. and also look to see if you have used one of those clear washers next to the nut instead of between the two leads. it probably is a washer with a neck on it and it slides through the plate and the fitting with a black wire. you might have grounded the thing.
Derick15
Sep 17, 2016 05:28 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 19, 2015 10:07 PM
