1990 Camaro engine swapp problem
Old May 28, 2009 | 11:42 PM
Tim98's Avatar
Car: 190 Canaro RS
Transmission: ???
Axle/Gears: ???
Please can anyone help me.
I bought a 1990 Camaro RS with a ACDelco rebuilt 350 tbi engine. The problem is it foods out very badly. I am woundering if the fuel pump is not right for the ACDelco rebuilt 350 tbi engine with two injectors. I'm thinking my Camaro had a mfi 305 origanally and the Peripheral Type fuel pump
in it is giving my tbi 350 to much gas. I hope I don't have to replace the fuel pump to the Rollervane Type fuel pump.
Thank You
Tim
Old May 29, 2009 | 12:26 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 1990 Camaro engine swapp problem
Welcome to TGO Tim98
Pump is probably not an issue in your TBI system. TPI pumps (or as you called it MPFI) can be used with TBI system & fuel pressure bypass regulator can bring it down to about 13-15 PSI. Never the less it is less than ideal having all this fuel constantly flowing through.
Both TBI and TPI '90 camaros used in tank Fuel Pumps - the difference was fuel pressure that the two can deliver. One commonly overlooked problem is a restriction in return line - a kink or a sharp bend in hose will increase back pressure rendering fuel pressure regulator useless. The only way to confirm that you have excess fuel pressure is to measure it. Another common reason for a rich condition is a bad CTS - verify that your SES light works.
//RF
Old May 29, 2009 | 01:40 AM
Tim98's Avatar
Car: 190 Canaro RS
Transmission: ???
Axle/Gears: ???
//RF
Thank you RF. After it warms up it starts flooding even more then I unplug the CTS sensor it runs better. Plus there is a small twist in the return line at the base of the tbi. Maybe we are on to something.
Tim
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
