LT-1
Old Jun 16, 2009 | 11:54 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
LT-1
I read through the LT-1 Section but am still a little confused I want to do the LT-1 swap on my TBI 305 is there any affordable springs i can get for it that would be available locally? (converting to TPI at the same time) whats the open and closed pressures demanded by the LT-1 cam? and would either of these springs work?
Max Outside Diameter 1.264 Wire Diameter 0.192 Coils 6.4 Closed Height 1.7 Closed Press 104 Open Height 1.21 Open Press 277
or
1.238 Wire Diameter 0.177 Coils 6.8 Closed Height 1.7 Closed Press 76 Open Height 1.25 Open Press 194.
Old Jun 17, 2009 | 05:23 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: LT-1
I assume you intend LT1 cam swap. In the LT1 cam swap guide is a part# for suggested springs and ewerithing needet except Air Condition. Best is to get the spring rate and dimension of the suggested springs as reference.
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
cRoe4
Aug 7, 2015 08:46 PM
BlazinOR
Nov 23, 2001 08:32 PM
elevario
Jun 16, 2001 11:37 AM
