TPS sensor
Old Jun 25, 2009 | 07:28 PM
elkora90805's Avatar
Car: 1989 Camaro RS
TPS sensor
Hello i need some help i have recnetly bought a TBI unit for a camaro.The original one i have is for a 1989 5.0 TBI and the onei bought is for a 1992 Camaro 5.0 the only difference is thta the TPS is not the same the on e i have is straight horizontal and the other one is oval will it affect it if i cut out the wires and connect a connector that goes to for that from the Junk yard any help is appreciated thanks
Old Jun 25, 2009 | 08:02 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TPS sensor
The connector pin out is very straight forward.
TPS pin out
Pin A is ground (black or tan)
Pin B is TPS signal to ECM - (blue)
Pin C is +5 volt reference (gray/pink stripe)
At idle you should get 0.6 Vdc and WOT around 4.3-4.5 Vdc
//RF
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
