Help, stupid thing acting up!
Old Jul 17, 2009 | 03:05 AM
Metallicamaro89's Avatar
Car: 1989 Camaro RS
Engine: Non-stock 350 bored .040 over
Transmission: Stock t-5 (soon to be t56)
Axle/Gears: Stock 3.08 (soon to be 3.73)
Hey, my camaro decided to take a massive s#it on me again. Here my dilema: I was out cruising around, when in the middle of an intersection my car just shut down. I pushed it to a parking lot where i tried to get her started and nothing. Then i noticed the injectors werent spraying on start up so i put some starting fluid and BAM it started right up but the injectors still were not operating. Since my dad was doing the spraying, I turned the car off but my dad didnt notice and continued to spray the fluid, and even with the car key to the OFF position the engine was still running then eventually died. Anyways, i figured it was a dead pump so I had it towed to my house. The next day i test the pump and it was starting up, even went to the point of dissconecting the fuel line to make sure it was getting to the injectors and it was. But heres the problem now, the car doesnt want to turn over anymore even with my putting gas directly into the intake, it just cranks with not even a split sec. of turn over. So now im worried. I recently had power windows installed and i was connectiong the switches straight to the power, i gues you need a relay, so ive been killing batterys left and right. Can that be a culprit of this? The injectors are less then a month old so it cant be those. Any help would be greatly appreciated, thanks
Old Jul 17, 2009 | 03:12 AM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Re: Help, stupid thing acting up!
Check all fuses? Under the dash, out by the battery?
Old Jul 17, 2009 | 11:58 AM
Car: 1989 Camaro RS
yup all good
Old Jul 19, 2009 | 07:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Did you check the oil pressure sending unit? It can go bad and not allow fuel to the injectors. It's located either above the oil filter, or on the china wall driver side of distributor. The connector has 3 wires, two are larger than the other. Remove the connector, and stick a paperclip between the two larger connections (unplug the fuse by the battery first). Then see if it starts. If it does, you need a new Oil Pressure Sending Unit (about $40).
Ghettobird52
Jul 5, 2024 11:18 PM
Cornholio7979
Sep 20, 2018 02:31 AM
Cleotiz
Jan 6, 2018 08:56 PM
Bob88GTA
Aug 18, 2015 03:31 PM
gta power
Aug 13, 2015 06:15 AM
