350 TBI Proper Fuel pressure setting
Old Aug 17, 2009 | 08:01 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
1991 RS From what I have read the proper fuel pressure for the stock 305 tbi is 13psi. I have swapped a 350 bored .30 over, mild cam, headers, and the 68# cop car injectors. I also swapped the ecm out of the donor car which was a 92 caprice police car. I have a new E3268 Higher than stock volume fuel pump that I will be installing this fall.
Down to my question....Should the fuel pressure be higher than 13psi for my application or will 13psi be adequate with the higher volume pump. What would be a good fuel pressure. Also, how do I check the fuel pressure.
Thanks in advance for any help
Jono
Old Aug 18, 2009 | 12:38 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 350 TBI Proper Fuel pressure setting
This recent post may bring you a step further.
https://www.thirdgen.org/forums/post...080-post7.html
Old Aug 23, 2009 | 10:25 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Read that and many other threads, still confused. Thanks.
Old Aug 24, 2009 | 03:16 AM
thomas1976's Avatar
Car: 91 Trans am
All LO3 I have mesured the FP were 11.5 psi (18-20 jears old).
LO5 with 68 lbs injectors + 12 psi supports around 250hp. So 12-13 psi may be anough for a stock police car. If the donor car had VRFPR, then FP was higher then 13psi.
You have done some nice moods to the engine, best now is to adapt the fueling.
Need to do some datalogs by progressively adding more trottle and observe %DC (dutycicle). Add fuel untill %DC stays under 85% and adjust the fueling # in the chip. Best and quickest is to upgrade to EBL flash for the tuning, no more chips, make changes in the bin, load and try it out.
Once you are ready to tune it, dont worry there are many experts that will chime in.
To mesure FP you need a inline adapter to plug the gauge, like in the post.
Old Aug 24, 2009 | 07:11 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Thank you!!
Old Aug 24, 2009 | 04:59 PM
Ronny's Avatar
This may he a useful tool
http://www.users.bigpond.net.au/ben_...ctorsizing.xls
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
pimp2303
Jul 27, 2017 02:03 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
