Fuel system problem????
Old Aug 18, 2009 | 12:06 PM
paul187texas's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI Swap to 350 TBI
I'm wondering if I'm headed in the right direction my fuel pump just went out the connector at the rear has three wires black-ground, purple-level gauge, grey-pump power. The purple reads about 11 volts and the grey is reading about 6 or 7 volts is this a relay problem and is it located by the brake cylnder?? I have continuety across the pump. 1992 Camaro 305 TBI swapped to a 1973/350 TBI I had to relocate the oil pressure censor from just above the oil filter on the 305 to the side of the distributor on the 350. I know oil pressure has something to do with fuel pump just thought I would throw that in there.
Old Aug 19, 2009 | 12:06 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Fuel system problem????
The fuel pump power should have battery voltage. If not, the pump will either not work properly, or not at all. Also, the oil pressure sender (as far as the pump is concerned), just provides a second source of power should the relay fail in operation. Its somewhat of a hold-over from the "choke" light on the carb cars.
Old Aug 19, 2009 | 06:26 AM
Car: 1992 Camaro RS
Well I replaced the fuel relay and oil pressure sender but I have just dicovered that I am loosing voltage to the relay and oil pressure sender when I turn the key to the on postion now I'm thinking it is an ignition switch issue or a ground issue coming off the fuel pump connector. Any ideas would be greatly appreciated.
Old Aug 20, 2009 | 06:54 AM
Car: 1992 Camaro RS
Alright so I hooked up power straight to the pump and it comes on and pumps strong now it seems that the throtle body is not opening up to recieve gas. It is just pumping in and going straight to the return.??????
Old Aug 25, 2009 | 06:32 AM
Car: 1992 Camaro RS
Can I get some help on this one???????????????? I recently took the throttle body apart and it seems that gas is getting there its just not getting past the injectors....
Old Aug 25, 2009 | 11:17 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
How much FP are you getting?
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
