my mechanic says its the carb pt.2
Old Aug 23, 2009 | 07:19 PM
My Buddy's Avatar
https://www.thirdgen.org/forums/atta...1&d=1251072716
https://www.thirdgen.org/forums/atta...1&d=1251072808
https://www.thirdgen.org/forums/atta...1&d=1251073009
So these are the pictures of my motor my mechanic says its the carb i was told its the throtel body but the problem is that the car wont stay on i believe the injectors are broken or something can anyone help me out thanks
thanks
Attached Thumbnails my mechanic says its the carb pt.2-img_0038.jpg   my mechanic says its the carb pt.2-img_0039.jpg   my mechanic says its the carb pt.2-img_0043.jpg
Old Aug 23, 2009 | 07:41 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: my mechanic says its the carb pt.2
that is definitly a throttle body.
Old Aug 23, 2009 | 08:06 PM
one92rs's Avatar
Car: SOLD!!!!!
ok do you own a timing light??? try to get it running and shine the timing light on the injector spray. see if it is spraying and dripping. it should be a uniform shower from the injectors.
Old Aug 23, 2009 | 09:00 PM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
I would be getting a new mechanic if they don't even know the diffrence between a carb and a throttle body injection system.
I would just get someone to hit the throttle with the ign. off first of all to see if gas is actually going through it. if not, I would unhook the fuel line to make sure fuel is actually being pumped to the injectors. then if it is I would expect the injectors.
obviously if someone trys to start it and you can see the gas coming out of the injectors thats not the problem.
I would also check the spark plugs, cap, rotor, ignition coil, fuses, just the basic tune up stuff. you could probably by a good throttle body off of someone on here for cheap if you have to or just switch the intake and use a carb, much better imo. good luck.
Old Aug 24, 2009 | 01:29 AM
My Buddy's Avatar
actually its a 1991 Camaro RS
305, 5.0
Old Aug 24, 2009 | 10:45 AM
fleetmgr's Avatar
Step #1 is to test the fuel pump to make sure it's getting gas from the tank.
Old Aug 24, 2009 | 12:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
305, 5.0
Which only came with a throttle body.
Moving to the TBI forum.
Old Aug 24, 2009 | 12:32 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Step #0, make sure you have gas in your tank.
Old Aug 24, 2009 | 05:06 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Did your mechanic seriously tell you that was a carb? :|
New mechanic time, next you'll have unicorns in your exhaust.
Old Aug 25, 2009 | 02:53 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Your mechanic is right... Also change your muffler bearings and replace your headlight fluid while your fixing it... Time for a new mechanic.
Old Aug 25, 2009 | 03:28 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would chek the fuel pressure and timing
Old Aug 26, 2009 | 08:15 AM
one92rs's Avatar
Car: SOLD!!!!!
i bet you have one bad injector. it will stumble miss cut up and then sut off. there not that expensive from vendors.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
webeeZ28
Sep 14, 2015 12:00 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
willyjoejr
Sep 3, 2015 09:26 AM
