hesitation problem
Old Oct 5, 2009 | 03:27 PM
Polo_Green92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock Open Rearend
hesitation problem
Hey guys I am having a problem with hesitation. It seems fine at start up and when I start driving for aprox 5 min or so I'll punch it and it has no guts. In ur oppinion what could it be? it shouldn't need tune a all it has is a 3" exhaust with the stock exhaust manifolds. I will say though the exhaust has a leak with probably a lot of the problem. I was just wondering what else it could be because I think the leak is by the muffler but not sure if there is another leak elsewhere.
Brandon
Old Oct 6, 2009 | 02:24 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Re: hesitation problem
Is this question in the wrong spot? The car is TBI and I was kinda wondering if it might have a little bit to do with the TBI. I mean I know that it could be any thing like I was also thinking ignition coil or the module because I did a tune up and those were the only things I didn't look at or change while I was doin the tune up.
Old Oct 6, 2009 | 04:18 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
These cars pull a little less strong before the engine reaches operational temperature, but its probably not your problem.
I would check, timing, Fuel Pressure, then 02sensor (if no exhaust leaks near it). Vinaldl datalog would help make diagnosing easyer.
Old Oct 6, 2009 | 06:52 PM
Car: 1992 Camaro RS
Engine: 305 TBI
ok thank you, yea thats one thing that I'm not sure about my dad and I put a new timing chain cover on it because the chain was rubbing on the oem cover and rubbed a hole through and I'm not sure what we set the timing at I think we set it at 0 not sure though.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
