91 RS Spark Knock, Ping, Detonation, Pre Ignition
Old Mar 11, 2010 | 12:23 PM
  #51
morepowerjoe's Avatar
Car: 86 Camaro
Re: 91 RS Spark Knock, Ping, Detonation, Pre Ignition
An update just in case anyone followed this thread. I have the engine tore down and found quite a few problems. First off, the side with high compression had a rebuilt head. I'm thinking this is why it had more compression. May be it was warped and it has been shaved to make it true again. I'm not sure. And the valves wiggle quite a bit when pulled a little ways out indicating pretty bad guides. Next thing was the piston ring gaps were lined up. I'm sure that doesn't help compression. And the rings are wore pretty bad. .032 gaps
Old Mar 25, 2010 | 09:18 PM
  #52
Car: 86 Camaro
It was the intake valves!
https://www.thirdgen.org/forums/tech...test-help.html
Old Jun 28, 2012 | 01:13 PM
  #53
Twiztid Tim's Avatar
Car: i have a 1991 camaro rs
Engine: 5.0
Axle/Gears: stock
i just replaced my intake man. and throttle body with 1 i got from the junk yard when cleaning it up to put it back on i noticed that the passages to the egr valve were clogged up!if you took off egr valve while it was on car you wouldnt know they were clogged by looking at it only viewing it from under the intake did i see it!but you can take a screw driver and try to poke it thru the passages to see if they might be stopped up!
Old Jun 30, 2012 | 04:29 PM
  #54
Car: 86 Camaro
Thanks for the heads up. I have like 4 or 5 of those danr intakes right now.
MM2Robinson
Oct 1, 2017 09:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
