Question About Swirl Port Heads
Old Nov 5, 2009 | 02:12 PM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Axle/Gears: 3.23Posi
In all the searches I've done I can't seem to find an answer to my questions.
1) Of the swirl port heads are there certain ones that are better than others?
2)Can you use a TBI manifold on TPI heads?
Any and all info would be appreciated.
Old Nov 5, 2009 | 10:15 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: Question About Swirl Port Heads
1) no not really.
2) yes, it should bolt right on as long as both sets of heads are the same bolt pattern (pre 1987, or 1987-1995 iirc,)
Old Nov 6, 2009 | 02:06 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
there is a big difference between 305 and 350 heads
Old Nov 6, 2009 | 11:23 AM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
I have a L05 in my wagon and I'm just lookin' to wake it up a little it's a DD.I have a LT1 cam and a 670holley TB for it,I have to do some more trouble shooting but it does have a valve train noise on the right bank.If I have to get them freshened up should I just polish up the ports or try and find a set of TPI heads? Did they make a 350 TPI ?or are they all 305's.And are they pretty common? Thanx
Old Nov 6, 2009 | 11:55 AM
all corvette tpi's were 350cid. camaro didn't use a 350 until around 1990 or 91. i have a 305 tune port system for sale cheap. you'll need 21lb injectors for a stock 350 or you can use 24lb LT1 injectors for a mildy modified engine as long as the cam makes at least 13in vacuum at idle
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
