zz4 350
Old Nov 11, 2009 | 11:27 AM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
zz4 350
what would a good tbi setup be for a zz4 350 create
Old Nov 15, 2009 | 08:54 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: zz4 350
I bet the cam would to set off the knock sensor.
Old Nov 16, 2009 | 08:36 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: zz4 350
I hate to be the ****, but you main issue will be fueling the motor. Search this topic and you will find out how to properly fuel the motor. Has been covered over and over and over.
Old Nov 16, 2009 | 09:19 PM
89Formula50's Avatar
Car: 89 Firebird Formula
Re: zz4 350
My dad runs this motor in his 88 camaro. He is running the cfm tech throttle body. With 350 injectors, adjustable fuel pressure regulator set to 13psi. also running the walbo 190 fuel pump.
Car runs perfect. cant run anything less than 93 or car will run a little rough.
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
