Fuel pressure 't' location
Old Nov 12, 2009 | 04:37 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Where is the best spot to put test 't'? Return line or supply line?
I have found both in my search not sure which is correct. The regulator is in the TB so, I would think the return line would be correct....just not sure.
Thanks,
jon
Old Nov 13, 2009 | 12:17 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Fuel pressure 't' location
The fuel pressure gauge must be installed on the supply line.
Old Nov 13, 2009 | 11:08 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Must be on the supply line. Most of the TBI "t" fittings are 16mm x 1.5 which is supply line.
Old Nov 14, 2009 | 06:42 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Thanks! Put a pemenant 't' on the rubber hose between steel lines under hood. FP is at 7 which would explain my f-ed up symptoms. Can't wait to pull the tank and replace the pump. (already changed filter) Thanks for the info!....Jon
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
